![]() | Home > General (L494) > Tow Assist |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5124 ![]() ![]() ![]() |
Not sure about the RRS2 but tow assist on the RRS1 was part of the surround camera system, so if you don't have that you may not have it, as there is also tow hitch assist I believe which is a different thing.
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
I’m 95% sure it’s optional.
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
There’s also advanced tow assist on top of tow assist, which is what the terrain response button thing does.
tsinc80697 Member Since: 10 Aug 2020 Location: Manchester Posts: 57 ![]() ![]() ![]() |
I definitely only have a rear camera and surround sensors, not surround cameras. I might speak to the dealer to try and obtain the original spec sheet. It would be a nice to have but not a killer as I've been towing with a 15 year old X5 for 3 years that didn't even have a camera to help line up the tow ball and hitch! |
That could be what I have then. But I'm not sure if I have the tow assist (if that is what helps line up the hitch) as I have an option in the reverse camera for lining up the ball. |
Drewlr4 Member Since: 05 Aug 2020 Location: South Devon Posts: 55 ![]() ![]() |
Im sure if you have deployable bar you will have tow assist. You have an option when selecting the rear view camera i think is the bottom of the 3 views listed which will zoom in on the tow ball when you get close. Tow assist options will not be displayed until you actually hook a trailer up and plug into the electrics that when you can list different trailers in the memory and get to use the Targeting sticker with the 3 black circles on it. |
I'll have to hook the trailer up to double check then. Hopefully it does have it! |
