Home > Technical > Oil Leak - could this lead to other major issues |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
I'd personally not use a main dealer but seek out a decent independent specialist in your area e.g. Oval Autos in Cradley Heath and Alltrack in Malvern are good.
Mon Aug 24 2020 8:29am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
I'm with Rob on this. I'd get it to a decent indie. If nothing else, it'll reduce the cost. It'll probably lead to a better outcome too as LR's dealers aren't known for being meticulous and thorough in their work. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 24 2020 9:30am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
As I was reading your post I was thinking " he's not gone to a LR Dealer has he?". So I concur with my two learned friends who've gone before me. Get it away from the dealer (assume its not warranty work) and find a good local independent LR specialist. Robin
Mon Aug 24 2020 3:13pm |
akalair Member Since: 21 Feb 2020 Location: coventry Posts: 28 |
After some toing and froing, the approved used warranty team have agreed to cover the leak as i reported a potential oil leak at the same time as the diff. (warranty expired over lockdown)
Mon Aug 24 2020 3:31pm |
If the mechanic doing the job does it properly, there shouldn't be any future issues associated with it.
Mon Aug 24 2020 4:49pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
As above at least it’s covered by warranty but now your out of it find a local indie, perhaps like DrRob has said above. Stay far away from main dealers now 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Aug 25 2020 8:01am |
Resurrecting this thread. Looking for help and advice....
Sun Oct 25 2020 4:03pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1134 |
A leaking rear diff pinion seal is quite common, and they should have fixed it quite easily - but it looks like they didn't.
Mon Oct 26 2020 6:59am |
