Home > Technical > Range Rover sport 2009 knocking from the front when turning |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
I had the same issue with my 2010. No play in any of the joints but it made a creaking noise when turning the steering, and it seemed to be louded in warmer weather.
Sun Aug 09 2020 2:03pm |
Bigben2k Member Since: 09 Aug 2020 Location: Kent Posts: 3 |
This is defiantly a knock metal on metal somewhere but no one can seem to find it including myself I had the creek noise before and as u did sprayed it up and has gone but this steering knock is driving me mad done antiroll bar bushes as they was knocking and that’s gone and now a new steering knock did the inner and outer tie roads and feels little tighter in the steering but still knocking when turning left and right |
Mon Aug 10 2020 5:48pm |
micknolan Member Since: 19 Apr 2017 Location: West Midlands Posts: 39 |
Maybe worth checking all 4 drop link bolts are tight, as had knocking on mine and when changing them one nut but was loose. |
Mon Aug 10 2020 7:13pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Have you checked wheel bearings? |
Tue Aug 11 2020 5:49am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
Does your vehicle have the hydraulic anti-roll bars fitted? If so, there is a known issue that moving the steering from side to side can cause a knock. Seems to be inherent in the system. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 11 2020 8:44am |
Yeah this one has the big motor type thing on the anti roll bar only thing I have noticed is the steering knuckle and the thing that connect the steering rack to the Collum has lot play in it and sounds like a knocking sound might replace that and see what I get as still get vibration from steering wheel |
Fri Aug 21 2020 9:09am |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 |
Mine was the same, changed the front ARB bushes and it sorted it. L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
Fri Aug 21 2020 10:23am |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 |
I have the same on a 2005 model. Changed loads and it still knocks, only i don't have the hydraulic arb's. I think we just have to learn to live with it. |
Tue Aug 25 2020 3:17pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Simple thing but check the wheel bolts are torqued up. 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Aug 26 2020 3:33pm |
