Home > General > High pitched beep when starting
gogsy1956
Coincidence or not??. Last week I fitted a new AC condenser,, no issues, today I got a mobile guy out to gas the system, started the car and moved it from the garage onto the drive, guy turned up added some gas and all appeared to be working OK. After he left I started the car and was greeted by a high pitched audible tone from the dash,, no warning lights,,car runs fine. Subsequent starts have resulted in the same thing happening,, never had this before, only strange thing was when the AC guy was there I was leaning across the front of the car to take off the battery cover as it makes life easier to get at the valves and I heard a double beep Asia I was trying to lock the car with a door open,,,, I assumed I had accidentally pressed the fob against the bumper. Could this be a parking sensor fault??? 6 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #603254 Thu Aug 13 2020 7:21pm
Press the eco button or unplug the ac pressure sensor and see if it stops
Post #603255 Thu Aug 13 2020 8:42pm
gogsy1956
Cheers Andy,, don't know if I have an eco button Embarassed,, but will certainly try unplugging the high pressure sensor tomorrow 2010 RRS, TDV8
22" overfinch
Post #603256 Thu Aug 13 2020 9:05pm
Stevepd
On yours it may be under the right temperature setting dial. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #603267 Fri Aug 14 2020 7:59am
Facelift RRS1 doesn't have the Eco button.
Post #603269 Fri Aug 14 2020 8:09am
gogsy1956
Just to put an end to this topic,,, took the car to team valley landrover after asking their advice,,,, bring it in as we're not sure they said. 5 mins after arriving allows sorted.
The image shows a black button,, 7 years I've had this car and always assumed this and the red led have been part of an old sat navigation supply as there is a supply cable tucked behind the A pillar. Now after all this time I find if you press this button it causes a high pitched beep when starting?? . God knows how it's connected but I willing out. Obviously when the AC guy jumped in the seat he pressed this button either by accident or just for the hell of it but that was the cause of the.beep. Glad it's sorted but ticked off it was something stupid. Lovely guys at team valley landrover for sorting it in a few minutes at no cost. 2010 RRS, TDV8
22" overfinch
Post #603660 Sun Aug 23 2020 8:15pm
Eaters
So, what's it for??? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #603698 Mon Aug 24 2020 3:18pm
gogsy1956
As I said I assumed it was a supply for some kind of portable device as there is also a power cable that comes up at the right side of the windscreen. Obviously something has been plugged in on top of the dash and the push button turns it on and off,,,, by why there should be an audible device connected in as well is beyond me.
I will be removing it I think as it gives you the Censored when it goes off 2010 RRS, TDV8
22" overfinch
Post #603707 Mon Aug 24 2020 5:07pm
Eaters
Laughing Robin
Gone:
MGZTT 190 2.5
Post #603708 Mon Aug 24 2020 5:08pm
Radar detector ?
Manually operated nav ?
Post #603714 Mon Aug 24 2020 6:37pm
gogsy1956
Aye,, thats what sprung to mind Andy 2010 RRS, TDV8
22" overfinch
Post #603717 Mon Aug 24 2020 7:00pm
