Home > Technical > 2013 Sport Power Tailgate
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Guys.
Got a small but Censored me off issue. So I press the open boot on the key fob. Sometimes this works and the boot opens fully. I then press the button on the boot and it closes again. All standard working stuff.
Lately I have been pressing the button on the fob and I am sure its releasing the lock but the boot never comes up. I have to manually raise the boot up. Sometimes closing it the boot will go down a bit then stop.
However if I use the fob again it typically unlocks, opens and then I can close as normal
Any ideas? ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #603089 Mon Aug 10 2020 1:45pm
Previously had similar issue, but seemed to be ambient temp related, if it was quite hot it did it occasionally, replaced the external switch between the rear number plate lights and has been fine ever since must be over 4 years now. Could have been pure coincidence as regards to the temp though.
Post #603116 Mon Aug 10 2020 10:09pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Interesting because I have exact same issue. I had the aftermarket close kit fitted several years ago. But recently the lid unlatches but fails to lift open. However If I push the tailgate closed and try again it always works on the second attempt. Strange that. Could possibly be a sticky release latch. RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #603120 Mon Aug 10 2020 11:58pm
McFarTech
The heat issue might hold some truth. I defo think its worse when its a really hot day. ===========================================
Post #603159 Tue Aug 11 2020 10:01pm
mrluke
I dont use mine very often , and noticed it was sticking sometimes
Greased up the sill , Works fine now as long as i use it every now and then in the hot weather
Post #603236 Thu Aug 13 2020 12:58pm
scrumps
Try recalibrating the tail gate.
The method is in the manual, possibly in the “Entering the vehicle” section.
For the L494 you do this:-
To reset the tailgate:
Manually close the tailgate.
Press the tailgate release button.
Allow the tailgate to fully open or open to the previously set position.
Press and release the tailgate release button.
Allow the tailgate to power-close fully. The tailgate's programmed memory is restored.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #603332 Sat Aug 15 2020 8:48pm
