![]() | Home > General > Parking sensor problem. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
You would like to think so, but being somewhat cynical there is as much chance of it being cheaper to produce and able to sell it dearer, after all this is L/R. |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 341 ![]() ![]() ![]() |
Thank you both for the advice. I'll put the old one back and see how we go. The only other issue I have with the car is the Sat Nav voice recognition not working (I have changed the mike). I've put up posts on the forum and never had a satisfactory reply to solve the issue. The diagnostic shows two codes. I have tried to make contact with Denzo and never received a reply. You two guys seem to have your figures on the pulse of every thing Land Rover related.....any suggestions as to what or where I can go next?!? Andrew Kennedy |
What are the two codes you are getting ?
Two codes Col...... 0B-41: 10/03/17 12:37:28 & 10-50:00/00/00 00:00:00. Apart from the voice recognition ever thinks works okay. The message I'm getting on the dash is "NO SPEECH DETECTED". We have a very good guy over here in Brittany who specialises in Land Rover servicing, repairs etc. The wiring from the box under the seat to the mike has been check for connectivity (if that's the correct expression) as okay....but that's as far as we have gone. If you can suggest any other checks that could be looked at, that would be helpful. Andrew Andrew Kennedy |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5095 ![]() ![]() ![]() |
Those are codes out the secret menu Col.
The continuity of the RED and BLACK wires that go up to the mike were checked by looking at the box (situated under the front seat RHD) from under the back seat, perhaps not very satisfactory. Interestingly your thoughts about a possible short, the system went on the blink intermittently before deciding it wouldn't work any more, which I guess might indicate a short. Perhaps I'll take the front seat out and have a look at the wiring? I haven't added any accessories screwed into the body that might have caused a short. Andrew Kennedy |
