![]() | Home > Technical > Leaking diff sorted today |
| Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321
Can’t catch a break |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Well done Steve. It never rains but it pours, eh?!
Sorry, I didn't read your post properly - notice it's the rear you have an issue with! |
Thanks Kev, can’t believe I forgot about that! I’ll check it tomorrow. It is the front diff that started leaking, I’ve sorted the rear with a new seal.
No problem. If it is blocked, the part number for the new breather filter is LR019450. It costs about £15 from memory. When you fit the new one, cut the pipe at an angle. This will prevent the right angle of the new filter sealing the top of the pipe. Kev
Thanks for that Kev, I’ve just been to have a quick look and checked the photos on the internet and can’t find it, I’ll have a better look tomorrow.
It should be just by your coolant bottle. If you try and blow down it and you feel the air compressing, it's clear. If not, chop it off and replace |
Cheers Kev, well it’s raining here this morning so I’ll try and have a look later if it stops? If it’s not been modified I’ll cut the filter off and see if the leak stops, I’ve got the new seal on order anyway. Steve
Well I found it hiding behind the AC pipes but couldn’t get any slack on it, all the AC and cooler pipes were fitted on top of it.
I had changed the oil in both diffs and transfer box recently but I’ll drain and refill the front again. Steve
So far so good, front diff not leaking anymore. Result |
Awesome |
It is Kev |
| All times are GMT |
