Home > Technical > Standard calibration in MM ride height
Apples24
United Kingdom 2006 Range Rover Sport TDV6 HSE Lux Java Black
This is a bit high
I have a fully up to date solus ultra
I’ve done it before with launch gear on a vogue
It asks for each wheel hight centre hub to wheel arch in mm and adjusts accordingly
What are the standard settings please?
Also gonna try drop it a bit
Do I put in it’s a little higher than it actually is so it lowers a tad further?
I know it has a wobble is the tolerance is out and done work
Thanks
Lee
Post #602735 Tue Aug 04 2020 5:04pm
Apples24
Success managed to lower it a tad
Post #602783 Wed Aug 05 2020 11:13am
knwatkins
Re: Standard calibration in MM ride height
462mm front, 463mm rear Thumbs Up
That's measured from the middle of the centre cap, vertically, to the arch.
When you run the calibration routine, you adjust each corner until all corners are at the correct level, then save. Kev
Post #602784 Wed Aug 05 2020 11:27am
Bear in mind that the figures stored in the car's suspension module are not actual height figures. They're just figures so that the system can see movement and which way it's going. You'll often see widely different values even though the corners are all at the same level. 2012 SDV6 - it's missing a couple of cylinders
Post #602810 Wed Aug 05 2020 4:27pm
