![]() | Home > Technical > help on Sat Nav update please |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1909 ![]() ![]() |
You should have a DVD unit under the front passenger seat that contains the sat nav DVD.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
I think yours in a facelift model being a 3.0 and all.
Ah didn't spot that! 2023 P440e SE Dynamic on order -cancelled
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 477 ![]() ![]() |
If yours is a facelift with hard drive you need to follow this link..
that maybe for an even later system.
dave4good Member Since: 04 Aug 2020 Location: Doncaster Posts: 3 ![]() ![]() ![]() |
it looks like mine is a 2010 version of the Sat Nav I think a Denso touch screen, if i go into navigation and then map updates it asks for a license key |
didn't know they did so many versions..
Apples24 Member Since: 04 Aug 2020 Location: Southampton Posts: 5 ![]() ![]() ![]() |
What about. A older 06 that doesent have a disc |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
If the OP 's car is a early Facelift MY10/11 variant the only people that can update the Sat Nav map is a Dealer, it can not be updated via a DVD Disc, Memory Stick or hidden menu, MY12 on can be done with a memory stick.
Disc should be under passenger seat |
It should be but it’s not it says I need a disc
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1557 ![]() ![]() ![]() |
I wonder if its worth all the effort! Guided by posts on here it seems that you can only upgrade older LR SatNavs so far, even with bootleg copies of newer disks from eBay etc. They are always going to be out of date and won't know about roadworks and accidents etc. And people seem generally to be pretty unimpressed with the newest LR SatNavs stuff when compared to other manufacturers (again from what I've heard here and elsewhere).
Thanks for all the advice guys,
So is your car a 2009 pre-facelft or a 2009 59 plate facelift variant ?
