![]() | Home > Maintenance & Modifications > AC condenser |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
I've got an NRF unit on my V6. It was the same size as OEM.
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 ![]() ![]() ![]() |
I fitted the Nissens unit from Advanced Factors. It comes with new seals too. Fits well. Aircon is nice and cold.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
Hi Drdeath,,, have looked at advance factors site,,, did you fit this yourself,, if so what issues did you have,, if any and how long did it take?? 2010 RRS, TDV8
Rusted bolts that snap is the worst problem on the bumper(cant remember if i took off front bumper to do air-con rad but i have had it off quite a few times hidden winch etc you need to ease the top slam panel up to get the rad out) and slam panel if your not doing them all the time i would allow yourself most of the day to be safe |
Started it today but just taking my time. Had the lights, grill and bumper off in an hour,,, hardest to move were the 2 selftappers on the underside on the corner of the wheelarch. All the slam panel bolts came out very easily and the panel itself was very easy to move forward. The two lower condenser retaing bolts were awkward to find but easy to remove. I'm at the stage now where the AC rad is loose but will only raise a couple of inches before catching on something. Had to manufacture a "special tool" in order to remove the tapper that holds the lower plastic shield in place as they are put in from the engine side,,, still struggling a bit to get ther rad out though. 2010 RRS, TDV8
They are quite tight in there i had 3 rads there on my supercharged you kinda have to lift the front panel up and forward to give some room i think if i remember hard to come out but slipped back in easier which i was surprised at i snapped two of the slam panel bolts and a few holding the bumper at the bottom too |
Took me about 3 hours all in to swap the condensor out. As said, the self tappers in the bumper were the worst ones to remove.
