Home > Maintenance & Modifications > advice please on jacking up rrs
adam01
Ireland 2007 Range Rover Sport TDV8 HSE Java Black
hi all
ive tried but just can not get the front wheels off the ground for a brembo brake pad change
ive put suspension on lock but seems to unlock it self , then tried the raise the suspension with trunk book open ,
and the front wheels still lower them selfs ?????
help please Sad
Post #602239 Sun Jul 26 2020 4:23pm
Normally people just jack them up using a proper jack.
Then axel stands
No need to lower suspension
Post #602240 Sun Jul 26 2020 4:29pm
adam01
ive a 3 ton trolly jack , but when i jack it up wheels do go off the ground -but quickly wheels go down before i could get wheel nuts off
Post #602241 Sun Jul 26 2020 4:33pm
gogsy1956
Have you checked to make sure it's not your jack that is the problem, one of my jacks does that,,,, and it's not exactly an old unit but it won't hold any substantial weight. One of these days I will repair it. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #602243 Sun Jul 26 2020 5:16pm
Dave-t
Does the book not say to raise it to off road height? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #602244 Sun Jul 26 2020 5:27pm
knwatkins
Perhaps your jack does not have enough reach?
I just remove the air suspension fuses to stop it self leveling when in the air, then just jack up from normal mode. However, I think you are right Dave, the manual does say from off road height from memory. I believe this is purely to cut down on the effort required to lift it up. Kev
Post #602245 Sun Jul 26 2020 5:31pm
1richard1
Hi if your jack hasn't the reach lock it in access mode.
Post #602252 Sun Jul 26 2020 6:54pm
riverblanche
where are you jacking it Question
I always used to Jack under the suspension arms, chassis Jack points and the body has to go a long way before wheel off the ground did use to adjust itself but never had a problem getting the wheel off the ground
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #602253 Sun Jul 26 2020 7:14pm
Pufftmw
Having spent some time today jacking mine up, jacking on the lower rear arms pivot on a 43cm 3 tonne Halfords trolley jack gets the wheels off the ground enough to get axle stand under and without maxing out.
Post #602255 Sun Jul 26 2020 7:15pm
garrycol
Australia
Re: advice please on jacking up rrs
help please Sad
What is this lock thing - there is no such thing as far as jacking goes - you jack the car up and the wheels stay on the ground until suspension travel is used up and then the wheel lifts.
What is with the truck boot open - this is nonsense.
The official way is put the car in offroad height - this is to minimise the amount of lift on the jack you have to do - put the jack under the jacking point under the chassis and start jacking, and jacking, and jacking and after a long time the wheel comes off the ground - then you can remove the wheel.
If you have a trolly jack or a hydraulic jack you can put it under the relevant front wish bone and if it is safe, when you jack it will lift the wheel off the ground directly rather than lifting the body first until the suspension range is exhausted then the wheel lifts. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #602273 Mon Jul 27 2020 4:02am
ondafly
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
do you happen to have put the car into access mode ? and thus its lowered/compressed the suspension. I've always jacked it up when in normal height, and just pumped away with a 3tonne trolley jack. No problems at all. Put chocks on the back wheels also.
Post #602278 Mon Jul 27 2020 9:07am
adam01
thanks guys did the brake pad change
i jacked her up on the flat part on wish bone with susp on the off road mode
all good now
thanks all
Post #602301 Mon Jul 27 2020 3:19pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Correct! That's the way it should be done! (and leave one door open)
 RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #602323 Mon Jul 27 2020 8:13pm
garrycol
Australia
If you are jacking off the wishbone rather than the chassis then the height of the vehicle does not matter. Also having a door open had no effect - it will stop a change of height which has to be activated with the console switch but does not stop the car leveling. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #602338 Tue Jul 28 2020 2:15am
