![]() | Home > General > RRS 2012 Rear Tailgate latch problem |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
Just out of interest does your n/s tail light work as that is also the power source for the tailgate switch between the number plate lights, if not check Fuse No. 25 ( Red 10 amp) behind the passengers lower glove box, could also check Fuse No. 15 (White 25 amp) in the engine bay fuse box. Could try giving it a thump by the latch while somebody operates the buttons just in case it's stuck and might release it. Only suggestions.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1550 ![]() ![]() ![]() |
I know I have a differnt model; and therefore design but, in case it helps, I did have an issue with my rear tail gate some time ago as my tailgate lock was stuck between unlocked and locked (!!)and it was looking pretty terminal. Indie thought they'd have to start cutting things like the trim inside to get to it. But they persevered and I think managed to get at the lock mechanism with a long bit of stiff sire (?) from under the car after taking our the rear floor shelf and the spare wheel.
