Home > General > New squsspesion & compressor
PC76
Hi all,
I am going to replace my suspension and compressor early next month (after pay day) and after recommendations / reviews on the dunlop struts & Dunlop (Hitachi) compressor.
these are the cheapest I can realistically do it for but want to make sure I'm not causing more work by going to the cheaper end of the market.
Also any pointers / additional consumables you would recommend purchasing prior to starting this next endeavour ....
Post #602032 Tue Jul 21 2020 9:51pm
Are you sure struts need replacement
Compressor could be serviced near pay day if you are ok with tools
Post #602041 Wed Jul 22 2020 9:27am
PC76
Hi Andy,
I’m on 150k Miles with off-road use, she’s like a bucking bronco on rough surfaces lol
Post #602044 Wed Jul 22 2020 9:45am
knwatkins
I renewed all four strut assemblies and the compressor and used Dunlop components. The ride is great and everything is working fine.
They are made in the UK and all good quality. Whatever you do, don't touch the Chinese tat on eBay.
LR Parts usually have the best prices...
https://www.lrparts.net/lr023964-air-suspe...relay.html Kev
Post #602045 Wed Jul 22 2020 10:42am
PC76
Thanks Kev,
LR parts are only a few miles away from me so will be looking to get the parts from them.
just wondering about fitting kits / fixtures & fittings that might / should be replaced at the same time as I don't want to be without it if I end up waiting for the parts to be delivered...
Post #602068 Wed Jul 22 2020 9:38pm
knwatkins
That's handy to have them on your doorstep!
The new struts come with new nuts on the top (3 per strut) and new VOSS connectors for the airlines. Make sure you have a 15mm flexi head ratchet spanner handy as it can be difficult to get to the furthest nut. The only other thing is the bottom nut and bolt but you can reuse those.
For the compressor, it will come with a new relay which is advisable to replace. All the existing fixings can be reused. One of bolts is a bit of a Censored to get back in but what you can do is put the bolt in the chassis first, then cut a slot in the bracket, slide the bracket over and tighten the bolt up afterwards. Kev
Post #602074 Thu Jul 23 2020 9:53am
PC76
Thanks again Kev, good tips.
Post #602075 Thu Jul 23 2020 11:11am
pwheeldon
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Java Black
I can confirm tge struts are cheapest at LR Parts as I've just had the front pair done. They were £210 +vat and delivery.
Post #602076 Thu Jul 23 2020 11:31am
knwatkins
Wow, they've gone up in price since I bought mine. I think I paid about £150 + VAT.
I bought from John Craddock as they were the cheapest back then. Kev
Post #602153 Sat Jul 25 2020 8:27am
PC76
So it looks like it’s been replaced before...
Only issue is what version has been fitted... hittachi or amk
Post #602435 Wed Jul 29 2020 5:11pm
knwatkins
Dunlops are a direct Hitachi replacement. So it'll be a like for like swap if you are replacing. Kev
Post #602441 Wed Jul 29 2020 6:00pm
PC76
Thanks Kev,
I had in my head that Dunlop produced two versions... don’t know why.
I looked at removing the compressor but looking at the state of the bracket and bolts I think I will leave it in place for the time being.
I took off the drier and opened it up. Confirmed it was the first filter disc only causing the problem so will replace it in the coming days with a service kit..
Removed it and moved the other filter disc as a temp fix so all is ok for the time being..
Post #602457 Wed Jul 29 2020 9:00pm
knwatkins
That's good news and should hopefully save you some money Thumbs Up Kev
Post #602461 Wed Jul 29 2020 9:39pm
