Home > Technical > Air Con
Ians63
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Air Con
Had the full system vac down and regas today. All checked out ok - system held pressure but could only get the air temp to drop by 1 deg! I have an IID tool and no faults read. Any help or ideas much appreciated. RRS 2006
2.7 TDV6
Zermatt Silver
Post #601987 Mon Jul 20 2020 9:16pm
gogsy1956
Who did the work??,, I would take it back and make sure there is a full charge in the system, and by that I mean the correct amount not too little or too much as it will not work correctly. not a lot to go wrong on these as there is only a few major components, an AC tech should be able to see if the compressor is working just by looking at pressures while the engine is running 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #602019 Tue Jul 21 2020 5:12pm
With the iid look at havc live values.
Pressure Should be around 100 psi
Evap temp. 5 deg if working
Compressor current. 100A !!?? If on.
Post #602021 Tue Jul 21 2020 5:33pm
1richard1
Hi best bet before being ripped off for regas is go to halfords buy the repair kit and refill bottle, most air cons after an age as long as there no big holes in the evaporator, the seals in the pump loose there oil and after a time the refrigerant breaks down.
Use the repair kit first then see how the systems is and then recharge as needed with the refill kit all in about £100 with the gauge that you have to buy but the upside you can use the gauge and refill for most other motors out there.
If that fails there may be other issues.
Post #602022 Tue Jul 21 2020 5:47pm
Ians63
Off and on IID screenshots
 RRS 2006
2.7 TDV6
Zermatt Silver
Post #602133 Fri Jul 24 2020 8:57pm
Shouldn’t it be 700 kpa
Post #602139 Fri Jul 24 2020 10:23pm
gogsy1956
Which values are you monitoring??,,,, is it suction or discharge pressure?. Either way it is only changing by 6 psi when the compressor cuts in which doesn't seem right, as Andy says if these are discharge pressures I would expect to see a much higher value. I would be tempted to double check you have a correct charge in the system,,,, also run the engine a bit quicker as it's barely ticking over looking at your screen shots, take it on the road and monitor your values this will make the compressor work a bit harder and also get some air flowing through the condenser. 2010 RRS, TDV8
22" overfinch
Post #602163 Sat Jul 25 2020 11:46am
Pressure is monitored where LR put the sensor.
Post #602175 Sat Jul 25 2020 12:44pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Had mine charged this morning, didn’t hold much hope of it working but it did Surprised we’ll see how long for but at least I know the system works. Drive home was like an ice box but it was only 16 degrees outside Surprised
Steve Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #602191 Sat Jul 25 2020 2:30pm
gogsy1956
Seems a bit pointlesslooking at live values if you don't know if it's high or low side,,, no substitute for a set of gauges where you can clearly see suction and discharge pressures. I've worked quite a bit on AC and fridge plant and know from experience that if you don't have a full charge in a system you are wasting your time trying to get the best out of it,,,,,, check for a correct charge and then move on to other areas. 2010 RRS, TDV8
22" overfinch
Post #602199 Sat Jul 25 2020 3:47pm
Well mine reads the equivalent of 700 so it’s lacking pressure
Try removing the valve caps.
If you get hissing the valves need replacement.
Post #602202 Sat Jul 25 2020 4:19pm
