![]() | Home > Faults & Fixes > 2.7 2005 rrs smoking |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
So the connection in the MAF sensor side where the preformed plastic ducting connects on the right hand side behind the fan so its probably the turbo air intake and not the intercooler pipe?.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9074 ![]() ![]() ![]() |
A leak in the inlet ducting will cause smoking because it results in overfuelling. Fix the pipe and you should solve the smoking. 2012 SDV6 - it's missing a couple of cylinders
Cheers mate. What holds the pipe on? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5060 ![]() ![]() ![]() |
The pipe snaps together.
