![]() | Home > Faults & Fixes > Coolant ..... HEEEEELP!!! |
Flashpilot1 Member Since: 18 Jul 2020 Location: The Shire Posts: 5 ![]() ![]() ![]() |
No ideas? Anyone? |
woodsie Member Since: 23 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
Think there was a problem with supercharger pumps being incorrectly wired on early 4.2s, might not be your problem but if you search on here for’ supercharger pump‘ you should find some info. which could be useful. Good luck and let’s us know how you get on. |
I’ve got no idea about these supercharged units. 2006 2.7 TDV6 HSE in Cairns Blue. |
Thanks for the help so far guys. I will look at the supercharger pump threads..... |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
Best off in the general or tech forum for future ref. Not everyone pops in here.
This is a slightly older engine without SC but may give you pointers
Andy....thanks a lot....I'll have a look. So the main water pump is off the belt and there is an additional water pump elsewhere? Course there is....why make things simple?! I'll repost on the other forum page too. Thanks for the pointer |
The electric pump is for the supercharger charge cooler. |
now I see the pic on a PC, yeah you may as well order a water pump |
