![]() | Home > Technical > Should this be attached |
Craigb86 Member Since: 09 Jul 2020 Location: Wales Posts: 74 ![]() ![]() |
I am genuinly taking all help on board and thank you ive been a subaru guy all my life so this is new territory and you've all been kind |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5054 ![]() ![]() ![]() |
Yes
Its rusted so id say its not been on years whats it to |
What year is it?
Its a 2006 4.2 sc buddy |
Is this something i can bolt or is it mechanic job i have impact compressor etc r
Yeah you can.
I’m guessing their will be a capped nut on the metal part so you just need a bolt. Andy.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
I would hazard a guess you have a couple of these missing.
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 ![]() ![]() ![]() |
Forgive me if you already know about the air suspension but if not; read the instruction book before jacking and getting under it. The suspension can drop on you. I used to put the suspension at off road height and leave the boot open. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9069 ![]() ![]() ![]() |
I seem to remember that disconnecting one of the body mount fittings was an LR fix for a noise/vibration issue back in the day. Might be worth having a search to see if you can find further info on it. 2012 SDV6 - it's missing a couple of cylinders
Thanks guys and no I'm 0 knowledge on the suspension thank you very much I will have a read first thats why i thought id come to guys like you im used to working on imprezas which are ancient so this range rover is a whole new world of pain lol the main start after garage is some treatment under the belly as its got start of surface rust so will carry that on thats what made me see those disconnected
