![]() | Home > Technical > upper screen after head unit install & rear dvd player |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5114 ![]() ![]() ![]() |
you either need to
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
1. that would be even worse |
Oh yes. I forgot you used the RCA to optical converter. |
hairy Member Since: 02 Feb 2020 Location: aberdeen Posts: 31 ![]() ![]() ![]() |
you can fit adaptors so that the screen/sat nav/4x4 info all work but you will also need the adaptor for the sound. These can be bought over the net and fitted very easily, ive already done it when I upgraded my stereo to dab etc. |
Oh no. Don’t go giving him more ideas |
...adapters eh ![]() |
the parts I used I bought from just car kits, if you gone to their website you will find everything you need, all pretty much plug and play. I fitted a Pioneer double din unit with DAB and added a revers camera as well, all fairly easy to do.
ah got all thoseish. its because am using a MOST decoder that i cant use em |
