Home > General > Dashcam power
idi
Dashcam power
Can I take the the power for a dashcam from the center dome light thing on he roof? I don't fancy taking the wire all around the windscreen to the fuse box. [/list]
Post #601377 Mon Jul 06 2020 9:54pm
Lindab
Here is a write up of what I did. Have fun
https://dashcamtalk.com/forum/threads/hard...ort.13011/
Post #601378 Mon Jul 06 2020 10:48pm
Not sure about the Aux but there is a Permanent Live up there in the Grey Plug to the left, red wire pin 1 if I remember right, plug normally used for sunroof.
Post #601379 Mon Jul 06 2020 11:01pm
idi
Good write up. I'll give it a go on the weekend. Thanks.
Post #601380 Mon Jul 06 2020 11:01pm
Scrumpy
Don't forget to buy a voltage regulator (if that's what they're called?) with the appropriate USB connector (either micro or mini) for your dash cam.
Most Dash cams need between 3-5 volts so usually you can't just connect it to 12 volt supply or it will fry your dash cam.
I tapped into one of the wires in the centre dome light (can't remember which one) and there's plenty of space up there for the voltage regulator box (you can get them on Flea Bay for about £10-£15).
Hope that helps. 2016 RRS SVR Estoril Blue
Post #601385 Mon Jul 06 2020 11:59pm
Would that not depend on the make of Dashcam being fitted, never had to fit voltage regulator on a Blackvue or Thinkware as they must be integral part of camera.
Post #601386 Tue Jul 07 2020 12:11am
Oldandconfused
Probably most decent dashcams are 12v these days, my Thinkware is and so is the wifes Nextbase.
If you have the park collision recording on your dashcam you will need a permanent live as well as a switched one. That being the case, get a couple of piggy back fuses and drop the wires into the fuse box below the glovebox.
Post #601387 Tue Jul 07 2020 7:45am
I piggy backed off Fuses 48 (Live) and 52 (Aux) fed the wires from the cam between the roof panel and headlining, down the door post under the door seal in to the fuse box, easy enough. If you have the rear cam as well did basically the same with that, fed the cable over the headlining and through the rubber conduit sleeve by the tailgate to the rear screen.
Post #601390 Tue Jul 07 2020 8:24am
derekmines
I used the ignition switched live up in the overhead console but instead of powering the camera directly I used a cigar lighter socket that I then plugged the normal dashcam power lead into... there's plenty of room in the headlining to lose the socket and it will make upgrading the camera much easier in the future.
Post #601391 Tue Jul 07 2020 8:50am
How much do these reduce your insurance by?
Post #601392 Tue Jul 07 2020 8:57am
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Didn't know they did, will be mentioning it on my next policy L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
L494 3.0L SDV6 Autobiography MY14 in Chile Red
L320 3.0L SDV6 Autobiography MY10 in Baltic Blue (RIP first RRS love 29/03/2021 insurance total loss)
Post #601395 Tue Jul 07 2020 10:11am
I don't know. I assume that was why Admiral kept asking me.
Post #601396 Tue Jul 07 2020 10:18am
Lindab
I agree with Scrumpy, most are between 3-5 volts. Check the dashcam instructions to verify what you need first. I would be wary of telling your insurance company, as if they give you a reduction on the policy, they will be expecting it to be on all the time your using the car. Nice get out for them if for any reason its not on or heaven forbid you are "slightly" above the speed limit when you have an accident. They are good to have if its not your fault, but you decide when to show the footage, not the insurance company.
Post #601397 Tue Jul 07 2020 12:44pm
Scrumpy
As Col says, I'm sure there are plenty of 12v models out there and probably the more expensive ones have something built in.
It was more a word of caution so you check first and don't risk frying the Dash Cam if it's not 12v like mine. 2016 RRS SVR Estoril Blue
Post #601401 Tue Jul 07 2020 7:09pm
Have to admit I generally have the voice recording and speed stamp turned off Smile
Post #601405 Tue Jul 07 2020 10:17pm
