![]() | Home > Technical > Engine riding!!!!!! |
Jacornel12 Member Since: 02 Jul 2020 Location: amsterdam Posts: 2 ![]() ![]() ![]() |
Hi Derek,
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
When you say "..the engine rides.." do you mean that the rev's increase, but the speed doesn't?
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 ![]() ![]() ![]() |
got the same issue lol RRS TDV6 2010 |
No it is not that the revs are climbing and the speed isn't. It is that the revs stick at 1500-2000rpm when releasing the throttle. Car just keeps pulling, sometimes really tricky, cause you have to brake against the engine (or put it in neutral) |
Ah, OK. They have an electronic throttle control, so it's not a sticking cable like it would have been 20 years ago. (Yes I am getting on a bit!).
Keijo Member Since: 27 May 2020 Location: New South Wales Posts: 8 ![]() ![]() |
Good advice Rob,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
The butterfly is there for EGR use.
Hi Andy,
Just a follow up on my comments above.
The diesel 2.7 only have one throttle butterfly.
Hi Andy,
I’ve removed the butterfly from mine which is what you are asked to do when the EGRs are blanked.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
There was nothing said about removing the butterfly when I read up and blanked my EGR’s?
Some sellers tell you, some don’t.
