Home > Technical > ACE leaking
Page 1 of 5 12345>
Wafoo
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
ACE leaking
I've had two months of fun in the car now it's payback time, first last week parking brake stuck on £1300 for new module, discs, pads and calipers as not covered by warranty now the ACE is leaking from the front drivers side, I haven't the time or inclination to do this myself, and yep, not covered by warranty, what's the average for this work, I'm rapidly falling out of love with this thing at the moment Sad
Post #600933 Sun Jun 28 2020 9:52am
Disco_Mikey
Less than a grand
Not a body off job
Post #600936 Sun Jun 28 2020 11:07am
mgrover
mine did same Sad i changed it manually.
parts here
https://www.ebay.co.uk/itm/Range-Rover-Spo...2749.l2649
its a body slightly raised job. while your there id say do both front and back. parts alone is about 500quid for front and back. but once body is up on an actual bench its actually a really easy job.
gotta also take into account that pipes might of seized in your valve block and a new one of those is also a tad pricey. also then theres 40ish quid for new filter, and lets say 20-30quid for fresh oil.
Post #600937 Sun Jun 28 2020 11:08am
Wafoo - where did you buy the vehicle? Was it privately or from a dealer? If it's from a dealer, take it back and demand they fix it. That is your right under the law. Don't be fobbed off by the "warranty says no, mate" response. They have a legal obligation to fix it unless they told you it was leaking when you bought it. 2012 SDV6 - it's missing a couple of cylinders
Post #600938 Sun Jun 28 2020 11:20am
Wafoo
I bought it private, FSH 12 months mot, did all my checks, bought a warranty as I've been bit before
But they don't cover Ace or the Electronic parking brake.
I'll probably chuck it in the garage that did the handbrake as I'm a contractor if I don't work I don't get paid, it's just a huge Censored but hey ho
I could live with a grand if that's the ballpark figure, I'll ring the garage tomorrow 😢
Post #600946 Sun Jun 28 2020 12:57pm
Brit Plumber
Well apart from the ‘thing’ I shan’t mention, you’ll have had 2 of what I would consider the 4 main things that would go wrong on that age of car. The ACE pipes, the roll bars, the EPB and the other one which I won’t jinx. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #600962 Sun Jun 28 2020 9:33pm
Wafoo
Is there a prize if I get all four? 🏆🏆
Post #600978 Mon Jun 29 2020 8:05am
mgrover
Tbf I think the bars only go if there's a leak and not enough oil getting to them
Post #600980 Mon Jun 29 2020 8:48am
Brit Plumber
I believe there’s no seals on the outer side of the bars and like everything else that rotates, they ware out and this is accelerated by dirt and contaminates. 2019 5.0 SC SVA (Current)
Post #600984 Mon Jun 29 2020 10:10am
Brit Plumber
There is a prize for all 4 but you won’t want it. 2019 5.0 SC SVA (Current)
Post #600985 Mon Jun 29 2020 10:11am
knwatkins
Rolling with laughter Kev
Post #600989 Mon Jun 29 2020 11:58am
Wafoo
Excellent, pipes corroded through, so sod it, pipes to be changed, new valve block, seal kits booked in for Thursday, just waiting for the suspension to give up the ghost to round off the week
Post #601003 Mon Jun 29 2020 4:17pm
daxmatt
New valve block ?
Post #601011 Mon Jun 29 2020 5:36pm
Wafoo
Garage say they have about 50% success rate fitting new pipes to the old valve body with corrosion etc, if it leaks the whole lot has to come off again, they're a Land Rover indie so I'll go with it
Post #601014 Mon Jun 29 2020 6:49pm
daxmatt
how much is one of those,,got to be £500 plus
just had a look on ebay,285 for refurbed one.
Post #601017 Mon Jun 29 2020 7:17pm
Page 1 of 5 12345>
