![]() | Home > Maintenance & Modifications > Parasitic battery drain. |
Mantaraman Member Since: 04 Jul 2018 Location: St Albans Posts: 16 ![]() ![]() ![]() |
Can anyone give me some ideas on what might be the cause, or how to trace a battery draining fault, RR Sport V8 Diesel, 2007. Drain is, I think, about 6mA.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 958 ![]() ![]() ![]() |
As Andy says, 13V is too low,, a constant 13V would not fully charge a 12V battery. I see 14.65 on mine,, it will vary but mostly it is the higher value.
Is it a calcium battery and is it a YUASA by chance? 2019 5.0 SC SVA (Current)
Thanks for the replies, I bow to your superior knowledge. I might have mis-read the ammeter when looking at the rate of drain, similarly, I might be mistaken on the charging voltage. However, what I do know is if I re-charge the (Exide) battery and disconnect it, for any period of time, there is no loss. If I leave it connected, after just a few days, the battery is flat. I must therefore assume that something on the car is pulling a current - but I don't know what and where to start looking. I shall repeat the test lamp/pulling fuses exercise in case I missed somehting first time I did it. I used the car this morning and almost everything works correctly - the drivers door window wouldn't, initially close up the the top, it would re-bound down as if the safety function had kicked in. Has anyone had similar window problems? |
The problem with some new batteries and what I’ve had with YUASA silvers (calcium), one they’ve gone flat, they are shot. They only ever get a surface charge. My CTEK would show green and fully charged but as soon as I tried to start the car, the charger would drop back to 3. It could we worth just getting that battery checked for peace of mind because if it’s a calcium battery, it will be knackered even at 4 months old. 2019 5.0 SC SVA (Current)
I originally thought the battery must be faulty. I bought it on eBay and contacted the supplier and returned it for checking. They've confirmed there is no fault - so the fault must be on the car - and this is confirmed as I get the same symptoms on another battery borrowed from another vehicle.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5114 ![]() ![]() ![]() |
see here for more info and a link
What’s your timeline,
Regarding your window problem,,, Keep dabbing on the switch until you get the window right too the top,, then hold the switch in the up position for 3 secs and release,,, your window should work correctly after that.
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
Have you checked your upper tailgate switch, this was the cause of my battery drain and many others on here.Have a look at my posts regarding battery drain |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
my rear window defroster caused my battery to run flat. Disconnected it, and all good. Wiring had gone bad on it. |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
Worth trying above suggestions, but it could be anyplace. It took an Auto electrician 3 days to find the parasitic drain on my car.
Thank you all for your comments, I've now learnt a lot more about the problem. With the engine running, the charge from the alternator is over 14.5V, the battery stays OK if I use the car - no fault here. The tailgate glass switch has collapsed - I've fixed this. The windows work OK at the moment - as does everything else.
Have you also pulled the relays? Maybe it’s a bad relay cycling? You could try pulling one at a time. 2019 5.0 SC SVA (Current)
