Home > General > Brakes
tjw2020
Brakes
Afternoon,
Need to fit new Disc brakes (front and rear) to RRS 2014 with 21 inch wheels.
I'm looking to buy them online but unsure on the Disc mm needed.
One site said that 360mm (front) and 350mm (rear) would fit.
But also offered up to 380mm (front) and 365mm (rear).
Does anyone know if the 360mm/350mm will fit or do i need to go for the bigger ones?
Thanks in advance.
Post #600837 Fri Jun 26 2020 2:34pm
I’d be surprised if you really needed rear discs.
Post #600838 Fri Jun 26 2020 3:02pm
tjw2020
When I bought the car in November, it came with an MOT advisory saying that all 4 disc brakes were worn/pitted/scorn.
7 months later and all the brakes are squealing, so I'm going to change all 4 at the same time.
Post #600839 Fri Jun 26 2020 3:09pm
I'd whizz a wheel off and check the dimensions as they are fitted to the vehicle. 10 minutes and it saves guessing. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #600840 Fri Jun 26 2020 3:57pm
Tyrefitter
Mine are 380 fronts & 365 rears.
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #600841 Fri Jun 26 2020 4:02pm
I thought squealing brakes was a standard RRS feature
Post #600846 Fri Jun 26 2020 6:18pm
gogsy1956
Have a quick look at advance factors site,, they are sponsors on here,, you will get a good bit of info if you search by vehicle type. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #600848 Fri Jun 26 2020 6:49pm
Pufftmw
Isn't that what copper grease is for?
Post #600850 Fri Jun 26 2020 7:22pm
Yeah or the special brake grease
Or the thing that goes on the rear or the pad.
My rears squeal
Post #600852 Fri Jun 26 2020 7:56pm
Brit Plumber
The only brake I’ve had squeal was when the rear right handbrake shoe lining broke down. Other than that, they’ve been silent. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #600853 Fri Jun 26 2020 8:27pm
knwatkins
No squeaky brakes here either. I always give a smear of copperslip on the back of the pads. I know you're not supposed to, but it's an old school habit that I cannot get out of Neutral Kev
Post #600859 Fri Jun 26 2020 10:04pm
If you have High Performance Brakes i.e. 6 pot Brembos on Front as per Andy's picture, they will be 380mm Front and 365mm Rear if they are Standard Brakes they will be 360mm Front and 350mm Rear. As for squealing I think you will find it was the cars fitted with the 6 pot Brembo's that had the main issue, mine certainly did, L/R even bought out a revised pad they termed as Anti Squeal after numerous attempts at curing it. Several TSB's on the subject as well.
Post #600861 Fri Jun 26 2020 10:16pm
Dave B
With regards to 6 pot Brembos, there was a 'mod' to the pads to stop them squealing, basically it was cutting a chamfer into the leading and trailing edge of the pads.
I have no squeal from using HAWK ceramic pads in my 6 pots, and no squealing from the Brembo pads in the rears.
If you use the brakes gingerly and often, there will be a build up of dust which will cause a squeal. Either washing the dust away with a hose or a few hard brakes can and will stop this though.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #600863 Fri Jun 26 2020 10:34pm
That Mod didn't work after a few K's it was back.
Post #600865 Fri Jun 26 2020 10:38pm
Disco_Mikey
Don't use copper grease on brakes. Were not in the 90's any more Whistle Laughing
The bulletin says to file a chamfer into the top edge of the pad Thumbs Up
Post #600872 Sat Jun 27 2020 8:19am
