Home > Faults & Fixes > Botched repair?
Keith1961
Northern Ireland 2011 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Botched repair?
Got a puncture in the off side front wheel and discovered leaking pipes with compression joints and a pipe with no connection!
I only bought this car in March.
See photos, is this dangerous?
What are their purpose?
Legal action pending?
Appreciate any help.
Post #600452 Thu Jun 18 2020 5:39pm
Tyrefitter
Where’s the pic Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #600453 Thu Jun 18 2020 5:44pm
Keith1961
Post #600457 Thu Jun 18 2020 6:46pm
Keith1961
New to this....older generation
Post #600458 Thu Jun 18 2020 6:49pm
daxmatt
ah,,the ace pipes,compression joints not really an issue,quite common i think,but not so sure about the open one.Looks like it might be the reservoir feed.Is the ace reservoir full of oil ?.
On a 2nd look,looks like they replaced the open pipe with a flexable one.
Post #600459 Thu Jun 18 2020 7:19pm
Keith1961
What is ace?
Post #600460 Thu Jun 18 2020 8:53pm
knwatkins
It's your hydraulic anti roll bars.
The pipes carry the hydraulic fluid around the system. Kev
Post #600462 Thu Jun 18 2020 9:10pm
Buckster
Keith1961 wrote:
What is ace?
Active Cornering Enhancement. Its used to control the anti roll bar system hydraulically on your vehicle 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #600464 Thu Jun 18 2020 9:31pm
Brit Plumber
Ugly!!
Well there’s 4 pipes like there should be but, If that pipe isn’t connected to another part then there’s obviously No oil which means the pump is likely toast but I would have expected you to have had warning lights on the dash. I think I’d be going back to the dealer (if it wasn’t a private sale) and telling them to sort. I think it will easily be a £1000 to fix. This is what I did to replace all of mine, I’m not sure how well the copper pipe will hold upto 300bar.
I can see what Daxmat was suggesting now, if the pipe is disconnected at both ends then as he suggests, it’s been by passed but it’s still a bodge. My repairs a bodge but it’s tidy and saved a lot of work lifting the body. If it’s leaking I’d still be pushing for a proper repair as the other pipes don’t look good and the mounting insulators have been cut away and cable tied up. And I’d be asking where all the under trays and guards are. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #600485 Fri Jun 19 2020 8:28am
Brit Plumber
Are your engine under trays missing? I can see you have some plastic trim missing but in some of the photos I can see ground where I’d expect not to. 2019 5.0 SC SVA (Current)
Post #600486 Fri Jun 19 2020 8:36am
Keith1961
The level is low as you predicted so I will top up today, I tightened the weeping compression joints when I had the wheel off.
I will keep an eye on the level from now on.
I have never used a forum before, thanks for all the advice, I really appreciate it! 👍😀
Post #600492 Fri Jun 19 2020 9:13am
Keith1961
I have never had a RRS before, certainly seems like there are parts missing, like the undertrays you mention.
I will contact the dealer after I get an opinion from our local Land Rover repair expert. (BLRC bear Saintfield.
I replied earlier before reading your post
Post #600493 Fri Jun 19 2020 9:23am
Definite bodge job. They've used a tie wrap to hold the pipe up. 2012 SDV6 - it's missing a couple of cylinders
Post #600496 Fri Jun 19 2020 9:48am
Brit Plumber
I would say new pipes at £250 plus flush and filter at the minimum and the missing shields. I appreciate they will says it’s an older car but I think those pipes will just get you by and they’ll fail again when your garage warranty runs out. 2019 5.0 SC SVA (Current)
Post #600509 Fri Jun 19 2020 11:14am
Keith1961
Thanks guys, I will get a price for proper repair from BLRC and challenge the dealer, I only had a three month warranty, but if the repair is deemed unsafe and likely to fail I may have a case.
Post #600512 Fri Jun 19 2020 11:27am
