Home > Maintenance & Modifications > Location of sump plug 2013 3.0l - last of the old style |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
well you remove the massive heavy engine guard.
Wed Jun 17 2020 5:33pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Don't know if there is a shortcut, but a bit of a performance to reset the oil level indicator on the dash according to the manual, not like the old days pour it in and check the dipstick.
Wed Jun 17 2020 10:28pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Changing the oil by removing the sump plug is fine but a real PITA. if you intend to change your oil every 6 months as I do then invest in a vacuum pump and suck it out the breather on the left side of the engine. It’s the pipe sticking up in the 7 o’clock position relative to tHe oil filler cap.
Thu Jun 18 2020 4:24pm |
Not quite sure why L/R would include nearly a 10 page section in the workshop manual telling you how to do it using a combination of the the c/c and menu buttons after doing a oil change if not required, unless I've misread it which is quite possible, or it's just L/R complicating thinks as usual.
Thu Jun 18 2020 10:14pm |
I can’t help with that Col but I have done about 6 oil changes on my 2013 Black and never done a reset and everything works just fine. |
Thu Jun 18 2020 10:32pm |
Just had a thought - is it telling you to reset the Service Required warning which I think includes the Oil Dilution warning, which I have never seen in my RRS. |
Thu Jun 18 2020 10:37pm |
I just wonder if it isn't reset afterwards whether it is showing a totally accurate reading, but if you refill with the correct amount and haven't had any issues I guess it can't be far out. No it doesn't mention the DPF or reset service indicator, not sure the RRS1 3.0 had oil dilution issues did it?
Thu Jun 18 2020 10:40pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
The oil service reset does impact how the car performs a DPF regeneration.
Fri Jun 19 2020 8:27am |
Are we not talking about two slightly different things here.
Fri Jun 19 2020 8:37am |
Ah, yes, sorry Col, my bad. Kev
Fri Jun 19 2020 8:39am |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 |
I've got the same car one of the very last of the old models and this was my plan every year staggered 6 months with the Indy service. However, this has an electronic oil level indicator through the menus so no dipstick. Anyone know how to do a top end change on these? L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
Fri Jun 19 2020 10:40am |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 |
Simples says L/R, make it sound complicated baked up with lots of pictures and pages and there you go they say.
Fri Jun 19 2020 11:05am |
Ignore that, found it.
Fri Jun 19 2020 11:59am |
