![]() | Home > General > RRS 2012 - Detachable Tow Hook Lock. |
I think you may actualy find the earlier one KNW500010 has been superseded to the later number KNW500020, a issue you may have is if Red plastic part of the ratchet is damaged this is not part of the new handle kit and not available separate from L/R or it never used to be, although it might be worth checking as it could be now.
sportgoogle Member Since: 13 Jun 2020 Location: Monmouthshire Posts: 18 ![]() ![]() |
Thanks,
Not totaly sure what you mean, but if you watch the Powerful video it should show you all the bits and how to change and assemble it, although it does go on a bit.
Thanks
If a part has been superseded would really have though it would be a direct replacement for the superseded part, as to why have vague recollection it may have been something to do with the key, but would normally assume it is because it's a improved design, but in L/R's case probably cheaper to produce and charge more for it. However I believe they also changed the colour from black to green.
Ok thanks,
I have found out why JLR changed the design of the Detachable Tow Hooks for the Discovery/Range Rover Sport.
Can confirm by finding both the later parts with ratchet of the Tow Hook.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
sportgoogle, thanks for posting your findings, I'm sure someone will benefit from this in future.
Haven't used mine for a while, but sure I have to pull it out and turn it to unlock and release it from the car, would possibly think if you didn't and just turn it that would cause wear on the plastic ratchet.
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
This is correct, I just purchased one for my new to me 2012 rr sport. I had to remove the red cover first and then pullout and twist the knob on the tow bar. The ratchet locks the pin in place and when you insert the towbar the small pin on the other side hits the car and this releases the ratchet. It wasn't going all the way home at first so I took a fine file and filed all the corrosion off the hole under the car, now it fits like a glove |
The thing is, is to be sure you have the later version Tow Hook Locking handle. To define which you have:- The larger is the later version ![]() |
Never really worked out why the Red ratchet part is not part of the later kit and you can't buy it separate from L/R as would have thought if that is damaged your stuffed.
I got my Red bit from Powerful albeit its black.
