![]() | Home > Maintenance & Modifications > Disco 4.5 / RRS 2 wing mirrors on a 2005 to 09 Sport |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Thanks for all the help Col and Brit Plumber |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5103 ![]() ![]() ![]() |
Guy, they certainly look like the one's, I can't be totally sure but although the picture looks right those L/R parts number they quote are for the the Disco 4, L494 Sport and the Full Fat L405 and I think Freelander which is certainly wrong. The D4 is the only one that will bolt straight on, one number they do quote LR051380 is a D4 heated powerfold mirror but not to sure it has approach lights, I don't wish to sound patronising in any way but I would ask for photos of the actual items as I would hate to see you pay a lot of money for something that is wrong.
Only been to Oman once it was rather warm, which is quite interesting realy as I should have been in Kabul but I think the plane took a wrong turn. |
Haha, that's been known to happen ... 🤣😂
I re-read my post again and it was a little misleading. What I meant to say was that the only bracket that will fit is the Disco 4.5 but the main frames of L405 and L494 are the same. The problem with the numbers you quoted I think will be RHD and he needs LHD. What I did was buy the basic Disco 4.5 mirrors from 2 different sources and then bought LHD L405 mirrors with everything on them and stopped the parts over. JLR were selling off a load of LHD L405 mirrors in the UK so they were cheap. I think all in it cost about £400 with black painted caps. I now have full spec mirrors on the car with camera, puddle light, Wade sensing, heated glass, blind spot, power fold, memory and auto dimming. I also have lots of other parts left to sell off like the LHD parts of the mirror etc. So sometimes it’s cheaper to buy multiple to get what you need. There’s also specific mirror glass for the Middle East but I think it’s just the wording on the mirror for objects apear closer.... I’ve spent some time at Thumbrait and Salalah in my time. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
The two numbers I quoted LR051371 R/H and LR051373 L/H are for Left Hand Drive vehicles, they are the basic version, heated powerfold, approach lights and camera, there are another 10 versions of each L/H/D mirror depending on options. The stupid thing is none of them new come with the mirror lens, camera, indicator lens, electric motor or approach lights etc. as I said probably find the only difference's are a few more wires in the mirror harness and extra holes in the housing. Personally I couldn't be bothered buying a bit here and a bit there, along with fact that when I did mine the D4.5 hadn't been in production that long so very few used ones around, so just bought all new parts from Dan when he was at Duckworths. I guess it's a personal choice and depends on which way they wish to do it if anyone want's to do it.
Apologies Cpl, I thought you were listing the numbers you bought but missed the LHD equivalent.
Just had a thought, if it’s the indicator in mirror you want, have you thought about the Powerful UK caps? I’ve not checked to see if they do an early mirror cap or if it’s just the 10 to 12. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
No Problem ![]() Cheers Col |
I'm actually looking at both power fold (as my 06 for some reason I can't understand doesn't have it) and the mirror indicators. I've seen the Powerful UK once they offer for the 05-06 cars and they look a bit ![]() ![]() Cheers 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
Agreed, very Citroen C3! Which is fine for a C3 of course before I get some abuse from Citroen lovers.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
HI Col & Brit ,
Straight swop with an additional wire to the mirror indicator taken from the Pos on the door indicator. Cols is a 2013 and mine is a 2012. 2019 5.0 SC SVA (Current)
As Chris said straight swap, if you have surround cameras that is a bit of a issue as the RRS1 will not fit the mirror and the RRS2 camera's are not compatible with the RRS1 wiring, although I did mange to modify and fit a couple of the reversing cameras and fit to the mirrors, and they do exactly the same thing.
