Home > In Car Electronics > Aux Lights on w/ High Beams
timbrehse
United States 2013 Range Rover Sport Supercharged Orkney Grey
I HAVE searched before posting but could someone kindly direct me to a post or tutorial how to
properly wire aux lights, specifically an LED light bar to come on w/ the high beams. My new-to-me ride (my 3rd RRS SC)
is a MY2013 and I don't want to at all risk damaging these fantastic AFS headlights.
Thanks in advance.
Post #599641 Thu Jun 04 2020 2:10pm
Pufftmw
It will be a hack as there's not a specific Aux Light for the 2013 RRS
This is an example wiring diagram https://www.extremelights.co.za/blogs/news...led-lights
Definitely use a relay solution and that shouldn't affect your existing headlights.
Post #599917 Tue Jun 09 2020 10:23am
timbrehse
TY Puffmw , now I just need to know which wire to tap
Post #599947 Tue Jun 09 2020 2:08pm
Pufftmw
There's an Aux Driving Light kit for the pre-facelift (like the one on mine) and it would likely be that the wiring diagram on that would be of help. There's a pdf for VUB502440 in this link https://www.rangerovers.net/threads/rrs-tw...help.34750
Post #599951 Tue Jun 09 2020 3:21pm
timbrehse
Thanks again - I'd seen that post AND the never ending instructions _ I know how to wire a relay - I just need " tap into the wire colored???? to facilitate On-With-High Beam (or Brights or UnDipped - however they're referred to in UK)
Post #599953 Tue Jun 09 2020 3:30pm
derekmines
I've done exactly this on mine, will check the wiring for you later and confirm which colour we tapped into for hi-beam
Post #599996 Wed Jun 10 2020 10:45am
timbrehse
That'd be Great ty
Post #599997 Wed Jun 10 2020 12:03pm
derekmines
So mine's tapped in on the nearside (that'd be the offside on yours I imagine) and it's a blue and grey wire.
We found it simply by using a multimeter and testing each wire in turn until we found the one that gave us 12v when the main beam was engaged.
I would imagine your wiring colours would be the same but you might like to check in the same way.
Post #600000 Wed Jun 10 2020 1:55pm
