Home > Technical > All terrain knob pushed down any benefits ??
Terryok
As above what's the difference with "knob up or pushed down"
Post #599920 Tue Jun 09 2020 10:42am
scrumps
“Knob up” = manual selection of terrain response setting.
“Knob down” automatic selection of terrain setting depending on what the car senses for power, traction, motion etc.
I usually operate “down” unless I specifically want something else.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #599954 Tue Jun 09 2020 3:52pm
your making that up! Rolling with laughter
It's just pushed down for all those who drive around London not needing it
Post #599958 Tue Jun 09 2020 4:51pm
The OP's RRS, assuming his profile is correct, doesn't have the auto Terrain Response as that was only fitted on L494, not L320.
The TR is pushed down to keep it out of the way, I think. I can't remember ever selecting a programme and then pushing the knob down when I had my 08 TDV8. My 12 SDV6 has a switch to change TR programmes so I can't now check.
If you select a TR programme, say mud/ruts, and then push the knob down, does it cancel the programme or does it remain selected? I would guess it'll stay selected and the knob is then just out of the way. When you turn off the engine, the programme will revert to road mode after a certain period so you can't leave it in an off road programme accidentally. 2012 SDV6 - it's missing a couple of cylinders
Post #599964 Tue Jun 09 2020 5:59pm
garrycol
Australia
scrumps wrote:
Scrumps
Haha - a joke I think - knob up means it is in the way but can be turned, down it is out of the way - there is no auto function on the OPs vehicle.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #599980 Wed Jun 10 2020 3:48am
Long time since had my TDV8 but I though pushed down it's permanently active and basically does it's own thing, when raised driver can manually control different settings, which is basically what Scrumps said I guess.
Post #599981 Wed Jun 10 2020 4:59am
garrycol
Australia
If in doubt read the manual Cool 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #599982 Wed Jun 10 2020 6:57am
Co9l
No Col, not on the L320 - there was no "does its own thing" facility. 2012 SDV6 - it's missing a couple of cylinders
Post #599983 Wed Jun 10 2020 7:19am
Surely if it's permanently active it must allow it to do doing something, otherwise in might as well just be switched of when the knob is down. I guess it depends on how you interpret what it actualy says in the handbook, although automatic probably isn't the right description.
Post #599985 Wed Jun 10 2020 7:46am
garrycol
Australia
I think you are getting confused as TR cannot be turned off (unless there is a fault). This is normally the onroad setting and the computer runs everything - the other TR settings have to be manually selected - there is nothing automatic about it - all in the handbook - just checked.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #599987 Wed Jun 10 2020 8:44am
aaronjb
I didn't even know my knob could be pushed down... fnarr, etc Laughing
Surely none of us actually read manuals? For anything? Ever? Hand in your man cards! Mr. Green 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #599988 Wed Jun 10 2020 8:52am
I didn't say it could be turned off, I said it was permanently active so it must be doing something in that mode. I also said automatic was probably not the right word to describe what it does do, but if it is controlled by computer with no input from the driver in that mode some may describe that as automatic operation. I think this is a debate that could just go on and on based on choice of words. Yawn
Post #599989 Wed Jun 10 2020 8:56am
If no special programme is selected, then the system just runs the default road-biased traction control / DSC settings. Centre diff can come in to play too, I think, but obvoiously on tarmac it's very unlikely.
Once a special programme is selected, then the various TC / DSC / HDC / centre diff locking progression are altered to suit that chosen special programme.
The question seems to be whether, once a special programme is selected, can the knob be pushed down and the selected programme still continue to work? I think it does, but I wouldn't bet my house on it. When I had my TDV8, if I was using a special programme, I always left the knob in the up position, partly because I would sometimes want to change the programme used whilst driving. 2012 SDV6 - it's missing a couple of cylinders
Post #600003 Wed Jun 10 2020 4:28pm
aaronjb
I am sad to discover that my 59 plate knob does not retract Sad
There's a joke in there somewhere... 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #600016 Wed Jun 10 2020 7:32pm
