Home > Technical > AC condenser |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
Yes |
Sun Jun 07 2020 5:58am |
2010 3.6L TDV8 Air Conditioning Malaysia Boleh!
Sun Jun 07 2020 12:14pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
Looking at the images I have found none seem to match exactly what I have,,,, are the front 2 rads part of the AC system?. To me it looks like the front 2 are AC, the next one is the intercooler and the one right at the back is engine coolant. Condensers I have seen for sale only indicate one Rad, No mention of the small one at the very front.
Sun Jun 07 2020 3:47pm |
is your profile correct? or is your car supercharged ? |
Sun Jun 07 2020 4:12pm |
Supercharged 3.6 TDV8 . Sometimes I wish it was a supercharged,,, profile is correct but sometimes ordering parts I've ended up with the earlier 2009 model as a lot of places lump the 2009/10 models all the same whereas in reality there are a lot of differences.
Sun Jun 07 2020 6:39pm |
my guess would be the middle one.
Sun Jun 07 2020 7:57pm |
I can see the pipes coming from centre one that go to the high / low pressure service valves,, which matches the line drawing from advance factors site,, just never seen mention of this tiny one at the front,,, might ask my indie.
Sun Jun 07 2020 9:14pm |
It's a fuel cooler 2010 RRS, TDV8
Sun Jun 07 2020 9:17pm |
No obvious damage.
Sun Jun 07 2020 10:09pm |
I changed my disco and sport ones they do suffer damage through the hole below the number plate.But you don't always see it but it is common |
Mon Jun 08 2020 7:32pm |
Yeah,, i've had a look about as best as I can but as you know most of it is buried out of sight,, I can see a slightly damp section on the bottom left of the condenser,, possibly oily residue from the refrigerant but no sign of any damage 2010 RRS, TDV8
Mon Jun 08 2020 8:06pm |
Well If you see oil. Change it. |
Mon Jun 08 2020 8:44pm |
