Home > General > Rear tyre inside wear
Themoog
This time last year I put a new set of tyres on the RRSS. The rears were wire on the very very inside edge of the rears.
At the time i couldn't be bothered with alignment.
A few days ago I noticed the rears are badly worn again - and that's about 5k.
My X5 with really obvious neg camber doesn't wear the tyres that quickly.
I'm going for alignment tomorrow and to swap the rear tyres side to side.
How can it be that bad? Anyone else have this issue?
Post #599587 Wed Jun 03 2020 8:57pm
knwatkins
That's odd. It must be way out. Please post your alignment results when you get your printout. It'll be interesting to see what the angles were on that corner. Kev
Post #599597 Wed Jun 03 2020 11:44pm
Themoog
There you go.
Post #599622 Thu Jun 04 2020 10:56am
knwatkins
It appears they were scrubbing because of the excess negative toe you have. That would mean that the rear wheels are toeing out where the front of the wheel is pointing away from the centreline of the vehicle. In addition, the overall negative thrust angle would have been causing the rear axle to crab over the left. I would expect the tyres to be feathered on the outside of the tread pattern. You can detect this by running your fingers around the circumference of the tyre where you will be able to detect high spots on one side of the tread block compared to the other.
Fingers crossed you won't have the same issue going forward as you have had it all set up Thumbs Up Kev
Post #599643 Thu Jun 04 2020 2:47pm
Themoog
Well I may swap the front and rear tyres over to extend their life anyway.
Post #599655 Thu Jun 04 2020 5:32pm
No wonder it was eating the rear tyres. They were well out! 2012 SDV6 - it's missing a couple of cylinders
Post #599658 Thu Jun 04 2020 6:14pm
Brit Plumber
And don’t swop sides if they’re directional tyres 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #599666 Thu Jun 04 2020 8:52pm
Themoog
Post #599678 Thu Jun 04 2020 10:49pm
