Home > Technical > C1A13 after new compressor
SomersetRRS
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Having problems with my 2008 RRS. Changed the compressor for an Aerosus Hitachi style replacement. I'm now getting a C1A13 fault code.
Any ideas or can anyone recommend a mobile tech in the Taunton/Bridgwater area who might be able to take a look?
Thanks.
Post #599419 Sat May 30 2020 3:36pm
From the manual:
Quote:
C1A1364 Pressure Does Not Decrease When Venting Gallery
Exhaust valve stuck closed
Exhaust valve does not
hold minimum retention
pressure
Gallery pipe
blocked/damaged
Pressure sensor fault
Air suspension exhaust
silencer blocked/restricted
pipe blocked/damaged
Reservoir valve block pipes
incorrectly installed
(unions reversed)
Refer to the guided diagnostic routine for this code on the
approved diagnostic system. Check the Air suspension exhaust
pipe and silencer for blockage/restriction. Check the reservoir
valve block pipes for correct routing and installation.
 2012 SDV6 - it's missing a couple of cylinders
Post #599421 Sat May 30 2020 6:44pm
SomersetRRS
Thanks for that. My understanding is that the exhaust valve is integral to the compressor so (I know it's not a 100% solid assumption!) that shouldn't be the cause. That being the case, what's the easiest way to diagnose the exhaust silencer/pipe, reservoir pipes and gallery pipes? Thx.
Post #599425 Sat May 30 2020 7:35pm
SomersetRRS
So this is driving me a bit nuts... I decided to replace the centre reservoir block as well as I was a bit dubious that this could relate to the pressure sensor but I still ultimately get the same fault.
Current situation:
1. Start up the car, pump kicks in and ultimately stops with a hiss. No issues at this point.
2. Check reservoir block with soapy water, no leaks, everything looks good.
3. Leave the car running, about 30 secs to 2 mins later, the C1A13 is logged.
Pump as mentioned previously is a Hitachi replacement from Aerosus (beginning to wonder if that was a good buy or I should have bitten bullet and bought genuine Hitachi) and the centre reservoir block is from Bearmach.
I've also tried removing the larger of the two pipes from the rear of the pump (which I understand goes to the exhaust silencer) to try and discount that being blocked but it seems I get the same issue.
Any help and ideas appreciated!
Thanks..
Post #600190 Sat Jun 13 2020 2:39pm
SomersetRRS
Hmm... so a bit more on this... I'm wondering if it's a wiring issue. Took the plug to the pump apart and reinserted and now, the fault doesn't come up unless I hit the switch to raise or lower the suspension. I've read on the disco3 forum that this might be due to wiring either behind the headlight or in the wheel arch depending on which MY my 57 plate car turns out to be. Anyone heard of this?
Post #600195 Sat Jun 13 2020 3:58pm
Disco_Mikey
I've had no luck with cheap, aftermarket compressors...
Post #600201 Sat Jun 13 2020 8:31pm
SomersetRRS
Beginning to think it was the wrong call although Aerosus was recommended by someone (not here) as something half reliable.
You think it's worth troubleshooting with that pump or just go for it and stick a Hitachi or reputable (recommendations?) OEM on?
Post #600203 Sat Jun 13 2020 8:43pm
Disco_Mikey
Ideally, you want a diagnostic tool that can activate the exhaust valve, and check for correct voltage, and load test the wiring, before condemning the compressor
But, I've never seen an exhaust valve wiring fault on an EU4 car Thumbs Up
Post #600205 Sat Jun 13 2020 9:14pm
SomersetRRS
Thanks Mikey. Would a GAP IIDbe able to do that? You think it’s worth looking at anything else other than suspecting the compressor now?[/quote]
Post #600210 Sat Jun 13 2020 10:37pm
erickwan
Malaysia
Buying good quality parts for the RRS goes a long way in eliminating future heartaches.
Post #600229 Sun Jun 14 2020 11:27am
SomersetRRS
In the spirit of providing updates on the final outcome of a problem. It was indeed the compressor at fault. Extensive diagnostics at a garage followed by swapping out the compressor for a genuine Hitachi solved the issue. Aerosus compressor being returned for a full refund!
Post #601434 Wed Jul 08 2020 3:57pm
Thanks for the update. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #601459 Thu Jul 09 2020 9:10am
