![]() | Home > Maintenance & Modifications > Constant Power Pin 9 Towing Electrics |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
13 pin has a couple of pins for that already, doesn't it?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
yeah pin 10 by the look of it |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
This is what I based mine on.
IanV8 Member Since: 06 Jan 2020 Location: Dunfermline Posts: 60 ![]() ![]() |
You do not want constant power to your fridge as it will flatten the car battery when the engine is not running.
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
My 2013 Sport has the 13 Pin electrics and the fridge and perm 12v both are wired and working.
I think fuses 48 and 54 in the fuse box behind the glove box are for the ignition feed (Pin 10) and permanent battery supply (Pin 9) to rear tow socket. 54 is ignition and 48 permanent battery feed.
