![]() | Home > General > RRS 06 TDV6 Suspension Dropping Overnight - Help Urgent :( |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9078 ![]() ![]() ![]() |
Valve blocks or air leak in a pipe. As it's both sides, that would suggest that the valve blocks have junk in them, probably desiccant from the air dryer in the compressor. 2012 SDV6 - it's missing a couple of cylinders
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Had the same issue , stripped and cleaned out the valve blocks (rear one was a pain)
Fiorano Member Since: 08 Feb 2020 Location: Coventry Posts: 4 ![]() ![]() ![]() |
Thanks guys!
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5066 ![]() ![]() ![]() |
I don't think you use petroleum jelly. Water is fine to get ride of white power.
I read somewhere that you use petroleum jelly.
Currently sitting at the garage.
