Home > Faults & Fixes > Rear view mirror plastic bit. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
If you are referring to the interior mirror they are only about £10.00 for the pair from L/R, but I think there is a choice depending if you have high beam assist etc. I recently replaced mine when new screen fitted.
Tue May 19 2020 10:38pm |
vshapedengines Member Since: 19 May 2020 Location: South Staffs Posts: 7 |
Thanks Col
Wed May 20 2020 8:03am |
Just had a quick look, if you have high beam assist it looks like you need LR018798 & LR018799 if you don't then it's LR024856 & LR024857 the stupid thing is the high beam assist one's appear to be £5.38 each what I paid and the non assist one's are over twice the price at £11.36 each but that's L/R for you.
Wed May 20 2020 9:17am |
Thanks a lot Col
Wed May 20 2020 1:55pm |
Col I am going to ask a very newbie question now. How do I know if I have high beam assist 😉. Can't see anything in settings? |
Wed May 20 2020 2:04pm |
Not totally sure, but If you go into vehicle set up via the menu it should be listed there so you can turn it on or off etc. if it's not listed I would imagine you don't have it. I have mine permanently disabled as it's another L/R gimmick that nearly works.
Wed May 20 2020 10:33pm |
Thanks Col
Wed May 20 2020 10:48pm |
Thu May 21 2020 9:18am |
No that is fine, no cover missing, it would normally be covered by the plastic cover you have missing at the moment, as soon as you replace the missing parts it will be hidden.
Thu May 21 2020 9:34am |
Perfect thanks Col |
Thu May 21 2020 11:58am |
