Home > Faults & Fixes > 2005 RRS 2.7 Suspension Fault |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1240 |
When you say doesn’t rise at all, is that all four corners?. Only because the rear looks decidedly down. If nothing rises then perhaps the common denominator is the compressor or or that area.
Tue May 19 2020 9:27am |
amgmaj Member Since: 28 Nov 2017 Location: Nottingham Posts: 79 |
Does not rise at all from any corner, the compressor comes on a few seconds but then stop once the warning light comes on... |
Tue May 19 2020 11:11am |
After a very quick search on here
Tue May 19 2020 12:27pm |
Could this pipe be the problem?
Tue May 19 2020 3:12pm |
If that's a hole i see then yes it will certainly not help search on here or disco3 to see hoe people have changed the air pipes and what with |
Tue May 19 2020 3:21pm |
Or even a quick search on the bay has kits too |
Tue May 19 2020 3:25pm |
Thank you very @ geoffsnook
Tue May 19 2020 8:15pm |
jmadro Member Since: 21 Nov 2019 Location: sevilla Posts: 3 |
Muchas gracias geoffsnook |
Sat Dec 18 2021 11:42am |
