![]() | Home > Maintenance & Modifications > inner wing guard cover coming away from inner arch? |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
Are the trim clips missing?
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
Do you mean the wheel arch edge protector, coming away like this pic or the large moulded inner wheel arch liner?
hairy Member Since: 02 Feb 2020 Location: aberdeen Posts: 31 ![]() ![]() ![]() |
yes exactly like your photo, no clips missing just the very outer edge? What do you do to fix this?
The fix is to replace the edge protector with a new one. I think the steel reinforce within the rubber corrodes and causes this. They are available as individual parts or you can get a set of four to replace all at once. A simple pull off and push on of the replacements. I think the part numbers are CLB500051-CLB500061. Around £70 for four bits of rubber!
thank you!!! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5078 ![]() ![]() ![]() |
Yeah, definitely get the Freelander kit six lengths in it, as said cheaper than the Sport one's and exactly the same stuff, if cut the lengths carefully can can do the whole vehicle twice as they really don't last that long, or sell the unused bits on and recuperate some of the initial cost.
thanks for the info, do you happen to know the part number for the freelander kit? |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I'm keen to hear about these as mine too need replacing. Having look around I foiund these which would seem to be the genuine RRS items:
Robin, those Freelander 2 ones are exactly the same stuff you get more and £20.00 quid cheaper.
Thanks Col. That's great. I'll go for a set those.
And a wee bit cheaper from these guys if you're not fussed about LR branded packaging.
Thanks Seatown. Have already ordered. Just bit the bullet or I’d still be deliberating next week |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 206 ![]() ![]() ![]() |
Thanks gents, just ripped mine off and waiting for the delivery man to replace! 2018 Telsa MS
