Home > General > Worn bolt removal
PC76
Worn bolt removal
Hi All, some of you will probably remember me asking for help with my seized handbrake module. Well being short of time and needing constant use I have not managed to get around to sorting it out once and for all as I have every Friday off in may Smile due to annual leave I need to take.
On my last attempt it is obvious it's been worked on before, the cover screws seem to have perished beyond being able to remove in situ and the bracket bolts look to have been worn down as I cant get any grip with my sockets.
So I know I need to remove the bracket so after the best method. I have seen some socket sets which claim to be able to remove worn bolts, has anyone used these and which is the best to go for?
Also is heat advisable on these as I want to re-use my module and avoid the £400-600 bill for a new one Sad
Thanks in advance & Stay Safe
Post #598423 Sat May 02 2020 10:11am
RobP
Irwin Bolt Grips https://www.amazon.co.uk/Irwin-Bolt-Grip-R...B0000CCXVZ have been a life saver for me
Highly recommended Thumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #598672 Thu May 07 2020 10:26pm
knwatkins
As above, the Irwin ones are known to be good. I have a set in my toolbox just in case. Kev
Post #598675 Fri May 08 2020 1:20am
I've got a set of those in my garage. Still in the original wrapping as they were bought as a "just in case" item. So far, so good and haven't had to use them on anything. 2012 SDV6 - it's missing a couple of cylinders
Post #598687 Fri May 08 2020 9:26am
Tyrefitter
As above the Irwin ones,,they've never let me down yet. Andy.
21 Ford Ranger
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #598689 Fri May 08 2020 10:00am
