Home > Technical > Engine ECU replacement
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
The engine ECU on my RRS maybe toast and codes unretrievable which means my next option is fitting a set of second hand matched coded units. My research so far tells me I need at least the ECU, fuse box and a key? But I have some questions I can’t find the answers to.
1 - Is this my only option?
2 - Is that all I require?
3 - What do I need to do with the key to operate the central locking?
Any help appreciated
Steve Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #598323 Wed Apr 29 2020 10:20pm
1 it’s your cheapest option
2 you need instrument cluster.
3 should be the least of your worries Laughing
If you have a gap iid this should dig you out of most holes
It can program keys for example
Post #598354 Thu Apr 30 2020 5:45pm
Devon Z
Thanks Andy, yes I forgot about the clocks Wink Ive posted over on Disco3 and been told I may be able to code in an ecu with the IID tool?
Steve Steve
Post #598355 Thu Apr 30 2020 6:07pm
Best to ask gap. They are very helpful.
Post #598360 Thu Apr 30 2020 8:53pm
Devon Z
Just been talking with Bell Autos and he said the same thing, special files required so I’ve emailed Gap. Could justify the cost of the tool and a useful thing to have going forward.
Steve Steve
Post #598361 Thu Apr 30 2020 9:01pm
Disco_Mikey
Ideally, you need a full set if modules that work on the HS CAN network
Different diagnostic tools read the VIN from different modules, and this can cause huge problems when it comes to diagnosing faults
Ask me how I know Censored Censored Censored Censored
Post #598374 Fri May 01 2020 7:30am
Devon Z
Heard back from Gap and my ecu type can’t be recoded from the tool only a new ecu can be done. I’m just hoping someone can read the codes from my ecu? I’m loosing confidence in the place that has it at the moment.
Steve Steve
Post #598379 Fri May 01 2020 9:29am
Devon Z
Hi Mike, are you saying it’s not just a case of buying a matched set of modules then? Can’t catch a break Big Cry
Steve Steve
Post #598382 Fri May 01 2020 9:51am
I think for around £250 a module set is worth a go.
You will have the wrong mileage I guess
Post #598392 Fri May 01 2020 12:43pm
Devon Z
I’ve looked at few sets and should I be concerned about the gauges? One set the temperature gauge wasn’t at zero and another the speedo showed 20mph. If their coded and faulty am I into another world of trouble?
Steve Steve
Post #598394 Fri May 01 2020 2:07pm
Dunno. Probably ok.
Buy a set that points to zero to be sure
Post #598395 Fri May 01 2020 2:11pm
Devon Z
I would go the ecu set route if if there was any information that it would work, nobody seems to of do it here or on Disc3. Steve
Post #598411 Fri May 01 2020 10:14pm
Disco_Mikey
We don't do it because:
Post #598414 Fri May 01 2020 10:49pm
Devon Z
That’s all very well Mike but I don’t know what you mean? Steve
Post #598416 Fri May 01 2020 10:59pm
Disco_Mikey
I had a D3 in for a new transfer case module
Replaced module, plugged in SDD, applied new firmware, car wouldn't start, and had every warning light in the world come on
The car had had a 2nd hand replacement EPB module, and so SDD pulled the VIN number from that, and downloaded the AS-BUILT data from JLR for said VIN, and applied that to the car, so the car was then reporting a different VIN and completely different CCF...
It was recoverable, but not after a few hours of shouting, swearing and panicking
For the car to start and run, you need the PCM, BCM, IPC and key from the same car. And that's assuming it the same spec etc, and CCF files match. But its not advisable for the above reason, and other modules will also need programming to clear VIN errors, which leads us to the above problem again...
Post #598419 Sat May 02 2020 7:44am
