Home > Technical > Another ‘suspension will raise when system has cooled’ p
CM07DAY
England 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Hi guys
Hope you are enjoying the sun in quarantine as much as possible Thumbs Up
Have been lurking and reading the forum but after reading all relevant posts I’m stuck
Here’s my situation
2009 2.7 HSE 142k
Currently on bump stops
‘suspension will raise when system has cooled‘ on drivers screen
No error codes, not in limp mode
4x4 screen shows green line at access height
4x4 screen shows no errors on any corner
4x4 screen shows ‘raising’ text
Height button on centre console illuminated and pressing buttons will change the lights
I have disconnected battery overnight, no lift
I swapped the relays around and still no lift
Checked the fuses, all good, still won’t lift
I removed the compressor and think it’s a replacement as the bracket was cracked and bolts missing
(I purchased car feb 2017 on 114k and I haven’t had it changed)
Bench tested the Dunlop 02567A compressor and works fine
Now I’m stuck
Any help much appreciated
Post #598014 Wed Apr 22 2020 4:29pm
The compressor has 2 temperature sensors. (they are the thin wires)
The obvious problem would be these sensors a faulty reading too hot
or the wires / connector pins from them back to the front of the car have poor connections.
Read the live values of the temperature sensors if you have an IID.
Post #598018 Wed Apr 22 2020 4:53pm
CM07DAY
I’ve not got an iid tool and they look pretty expensive
Post #598019 Wed Apr 22 2020 5:01pm
Check the connections to the small wires in the compressor then
Post #598021 Wed Apr 22 2020 5:10pm
CM07DAY
Is it this
If so how do I test, as it’s sealed
Post #598022 Wed Apr 22 2020 5:33pm
CM07DAY
update:
i bit the bullet and purchased a replacement dunlop unit and the suspension now raises Thumbs Up
however its way slower than before and now comes up with 'vehicle raising slowly' and once reached desired height, the pump continues to run Censored
i put it into standard height, engine off, listened to each arch, no leaks heard, did the same in off road height, and same no leaks heard.
currently left it in off road height, removed relay, and will see if it drops overnight.
any suggestions where to look?
Post #598318 Wed Apr 29 2020 9:35pm
DrRob
Is the reservoir tank rusty? If it has a hole then pump will over run.
Ideally you need the codes reading to get a better idea. The gap IID Bluetooth will pay for itself eventually with these cars Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #598320 Wed Apr 29 2020 9:44pm
CM07DAY
the reservoir tank did cross my mind actually, will have a look in the morning to see its condition, however living on the southcoast its not gonna be pretty under there Big Cry
Post #598321 Wed Apr 29 2020 9:50pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Spraying soapy water over the tank might help show up any leaks as it'll bubble....
Post #598343 Thu Apr 30 2020 1:45pm
CM07DAY
Update:
Left in off road height for 24 hrs and didn’t drop, so does that mean the valves are working and/or the bags are ok? Still no sound of leaks from each corner?
Now it’s lowered to standard height and sits square also
The pump still runs continuously, I switched off after 2 mins as not to burn it out. Also removed relay again
However when observing the 4x4 screen on dash, I noticed very sudden ‘jumps’ of the n/s/r wheel, the green line is straight with no red lights on any corner
Post #598348 Thu Apr 30 2020 3:50pm
DrRob
Height sensor? Without reading the codes with an IID or similar then a guessing game.
or:
Gumtree 4x4 in Burgess Hill
Sussex Vehicle Services in BH
Cedar Garage in Worthing * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #598349 Thu Apr 30 2020 4:06pm
Are you sure the relay is ok ?
Swap it with another maybe
Post #598353 Thu Apr 30 2020 5:39pm
CM07DAY
Yeah planning to get it read as soon as a garage is open again!
New relay came with new compressor
Post #598365 Thu Apr 30 2020 10:01pm
CM07DAY
So had it plugged in and after the initial codes were reset, no codes came up relevant to the suspension
However it is very clear that the back raises immediately and the front is incredibly slow, with the ‘vehicle raising slowly’ message
Which points to valve blocks maybe? Would it be front or could it also be centre block?
No obvious leaks from tank or pipe work either
Post #598521 Mon May 04 2020 1:37pm
DrRob
Post #598541 Mon May 04 2020 6:49pm
