![]() | Home > In Car Electronics > clock on dashboard how to set with Alpine audio unit fitted |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5127 ![]() ![]() ![]() |
I think you need to reconnect the battery at midnight |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
I'm surprised that the clock doesn't automatically set itself like on an iPhone. The tech has been there for decades. RRS (MY13) Santorini Black SDV6 HSE luxuary
Yeap. Though it would still use the factory radio which is missing |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1919 ![]() ![]() |
Not sure any/many cars set the clock 20 years ago? 2026 P460e Autobiography on order
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
The dash display is controlled by the OEM radio clock - as the radio clock wanders off time so will the dash display - if there is no signal from the radio the dash display will just tick over.
Kev H Member Since: 26 Apr 2020 Location: Lichfield staffs Posts: 12 ![]() ![]() ![]() |
do you think disconnecting the battery will work as there is no time showing at all on the clock ?. |
Have you selected the clock with the indicator stalk. 07MY RRS TDV6
Gary thanks for getting back to me, when I select settings with the indicator stalk I cannot enter settings do you know why this is, what I am doing wrong or not doing ?, any help would be appreciated |
Sorry cant help with that - I simply push the i button on the stalk to scroll through the various displays. 07MY RRS TDV6
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I don't know if it helps but I replaced the original head unit with a Pioneer double din one and I got all the wiring harness from IncarTec (site sponsor and really helpful guys).
Tilz Member Since: 23 Jul 2020 Location: Harrow Posts: 9 ![]() ![]() ![]() |
I had this issue recently on my RR Sport. After ages trying, i worked out that you need to turn the head unit "off" and then you can enter the display settings (using the steering wheel controls). |
