Home > Maintenance & Modifications > Front Pad Question
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Front Pad Question
Hi Guys,
Taken the front pads out of my front calipers (caliper painting.) At first I thought they where low, but looking at the Brembo pic online, they should measure 16.6mm from rear of pad to front face. Mine measure about 13.5mm. I guess they are still fine??
2019 SVR 2018 SVR
Post #598132 Sat Apr 25 2020 4:21pm
16.6mm would be the thickness of a new pad, do not know your mileage but that would account for the wear not sure what lining thickness brembo advise changing them at, normally around when the wear gets close to the bottom of the two "grooves" in the lining I would imagine. L/R recommend minimum wear thickness of lining 3mm personally I would change them well before they got that low The wear indicator should illuminate when pads around 75% worn which would be advisable to change then at least. The backing plate on the pad is 5mm so in theory you could go around 8mm total thickness.
Post #598151 Sat Apr 25 2020 10:59pm
the_big_1
Hi Col,
They have worn 3mm in a year. I am thinking that's nothing to be honest. If I went another year , would be at 10mm which is still more than 50% lol 2018 SVR
Post #598152 Sat Apr 25 2020 11:13pm
Personally I would change them when they were worn down to 4/5mm minimum. Thumbs Up
Post #598154 Sun Apr 26 2020 2:03am
