![]() | Home > Technical > 2.7 TDV6 crankshaft front seal replacement |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Either:
Ok, thats great thanks. I will have a look on D3 site first then. |
Ok, after more investigation and cleaning up and going for a drive with engine trays removed, i have found the following:
If the hole in the belt cover is wet, then something behind the belt cover must be leaking
Ah, didn't realise that was a belt cover, i thought it was the oil pump! |
Any thoughts on transfer box & turbo leaks? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
It’s normal for there to be a big of oil around turbo. |
Yes but it seems to have worked it’s way down and gathered a bit. What’s the fix, new hose/s or turbo itself?
Tighten jubilee clips a little.
