Home > General > New engine ?
knwatkins
If the reason you think you have a head gasket split is because you are losing water, have you confirmed if you have water in the oil or not?
Obviously combustion gases in the coolant system will only test for a pathway between the combustion cylinder and the coolant channels. If there is a split in the gasket between the oil galleries and the coolant channel, this would not show up in a sniff/combustion gas presence test.
If you have water in the oil, it is likely occuring from either the head gasket as you have previously suggested or the oil cooler. I appreciate you have a TDV8, but on the TDV6, the oil cooler built into the oil filter housing has been known to fail thereby opening up a pathway between the oil and coolant systems. Usually, the result is oil in the coolant due to the fact that the oil pressure is highest at this point. However, do not discount this because of this reason. Kev
Post #597670 Sun Apr 12 2020 1:48pm
dashingdave
Kev, no water in oil just to add to the mystery. The oil cooler idea worth a look, thanks. D
Post #597671 Sun Apr 12 2020 1:54pm
If the the oil cooler were leaking oil into the cooling system surely it would show up as a raised water level, in addition as oil floats on water would it not also be evident in the header tank as that is the highest point. If it was the reverse it would show as emulsified oil in the engine.
Post #597688 Sun Apr 12 2020 10:28pm
knwatkins
Yes, I agree Col, that's why I asked if Dave had checked if there was coolant in his oil.
The coolant has to be going somewhere so if the combustion gases and coolant system are fully isolated, the next best guess would be in the oil. However, he has confirmed that there is no emulsification. Kev
Post #597689 Sun Apr 12 2020 10:36pm
As far as the water finding it's own level when topped up, even my S/C does that when topped up to the level mark, no matter how many times you do it, it always drops by a small amount to find it's own level below the mark and always has done, even my old 4.6 P38 did exactly the same thing.
Post #597690 Sun Apr 12 2020 10:51pm
DrDeAtH
It could be the EGR coolers failed... water leaking into the exhaust system and being evaporated...
Post #597753 Tue Apr 14 2020 10:35pm
dashingdave
...sadly it's looking like the head gasket probably between the water and oil galleries. Yellow sludge on filler cap and pressure in the system pushing water out of the loosened cap. When the cap was tight it blew one of the hoses off. Performance still very good. Going to try the gunk first in the shape of SteelSeal. If unsuccessful then sell on cheaply...loads of new parts last 5 years.
Or get a price to remove heads skim and refit. The gunk in two bottles is £54, wouldn't that be a result !! Let you know.
Post #597783 Wed Apr 15 2020 8:16pm
knwatkins
Did you run it without coolant Dave? Kev
Post #597784 Wed Apr 15 2020 8:20pm
dashingdave
Probably but kept an eye on it. Got test kit coming but just thinking it may test negative if not blown on combustion chamber.
Post #597785 Wed Apr 15 2020 8:26pm
dashingdave
(Item ID: eBay Item No. 283852829188) on eBay. The Steel Seal worked for a short time but now looking like a heads off job. I'll get a price to do but in the meantime it's advertised at £2500. Crying or Very sad
Post #597900 Sun Apr 19 2020 3:19pm
chrbro
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Found my water leak was a distribution unit in the vee so all the coolant was evaporated before it hit the ground. £200 rather than the heads off 🤦🏻‍♂️👍🏻
Post #626337 Mon Aug 29 2022 8:35pm
