Home > General > Tdv8 issues after turbo
Dannyboy444
England 2009 Range Rover Sport TDV8 HSE Orkney Grey
I'm hoping someone may be able to point me in the right direction here.
Basically ive bought myself another range rover needing 2 turbos.
I've changed the turbos, cleaned all the pipework, intercooler and sensors.
Now I have a couple of faults showing and the car is sluggish but still drives ok
When plugged in also the MAF readings for both banks are slightly out and one actuator is showing 10% the other 100% but there both free and both cycle fully
Any help would be great
Regards
Post #597751 Tue Apr 14 2020 9:44pm
Dannyboy444
Sorry 2009 tdv8
Post #597752 Tue Apr 14 2020 9:47pm
Brit Plumber
Are the TDV8 actuators vacuum activated? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #597763 Wed Apr 15 2020 10:20am
Dannyboy444
No there electronic, both moving aswell
Post #597765 Wed Apr 15 2020 12:12pm
Any chance they need some form of calibration?
Chers
Post #597766 Wed Apr 15 2020 12:33pm
Disco_Mikey
New, recon or 2nd hand?
Post #597767 Wed Apr 15 2020 12:48pm
Dannyboy444
Recon units
Post #597789 Wed Apr 15 2020 10:45pm
Disco_Mikey
For this very reason, I only fit brand new units
The actuators are very, very sensitive to their mounting positions, and calibration can only be carried out 2 places in the world, AIUI
That said, wiring checks first. If they check out fine, then its Turbo back off I'm afraid
Post #597814 Thu Apr 16 2020 10:41pm
Dannyboy444
Thanks for that buddy, any particular places worth checking first? Or is it just a matter of going through all?
I bought it with faulty turbos also so I don't even know if the fault was there before hand 😂.
1 injector was slightly low so swapped that out and now all 8 are just either side of 1000.
I've had it on the iid tool today actuators seem to work correctly as does everything else, map seems to fluctuate very slightly on the graph MAF readings are slightly out from each other but both seem to act similar as it's revved.
Keep getting random p132e code now but not very often mostly just error message on dash but regardless the car just seems to fly just an odd stutter as it comes into boost sometimes.
I'm goner let a friend have a look next week I think as I havent really had time to do anything myself as I'm still working everyday.
Thanks for the input
Ta
Post #598026 Wed Apr 22 2020 9:11pm
Disco_Mikey
Live values should be between 5-95%
If that's reading correctly, between commanded and actual values, next step is a smoke test
Post #598027 Wed Apr 22 2020 9:38pm
Dannyboy444
I was thinking of building a smoke tester if I get chance, I think off top of my head they went from 10%-95% but opposite each other when turning ignition off/on
Left would be 10 right 95 then swap
Regards
Dan
Post #598031 Wed Apr 22 2020 10:36pm
Disco_Mikey
Should both be identical...
Post #598037 Thu Apr 23 2020 6:00am
Dannyboy444
Oh that's strange then
I'll have a look
Ta
Post #598047 Thu Apr 23 2020 9:09am
Dannyboy444
Well thought I'd update just for anyone who may have similar issues
First thing I thought was that I'd put the actuator on the wrong way on the passenger turbo. So I moved it do the rid was the other way, still had problems.
I plugged it in and got all the following problems changed injector etc.
Still scratching my head, I decided I'd put the actuator rod back the way it was initially and hey presto it's been fine, 🤦
Oh well all sorted now time to do bushes tyres and tracking
Post #598998 Sat May 16 2020 10:08am
