![]() | Home > Technical > Diesel Leak under engine |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 223 ![]() ![]() ![]() |
Hi Guys and Gals
Anybody???? 2015 L494 SDV6 3.0 HSE Loire Blue
rob cupples Member Since: 27 Jun 2018 Location: Stirling Posts: 30 ![]() ![]() ![]() |
I had an issue with non genuine fuel filter not sealing properly. Fitted a genuine and problem solved. Drain underneath can also work loose or snap if over tightened. |
Ok, thanks for replying.....will check it out when i can 2015 L494 SDV6 3.0 HSE Loire Blue
Yeah thanks Kev, will need to get underneath and remove the covers and the heat shield to reveal the fuel filter, then start her up and see where it's coming from 2015 L494 SDV6 3.0 HSE Loire Blue
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
remove the plastic under tray below the gearbox (where the front doors are) |
Yeah thanks Andy, seen a video on youtube 2015 L494 SDV6 3.0 HSE Loire Blue
Update:
