Home > General > Internal trim removal?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. Having problems with the rear parking sensors. Had the rear bumper off. Checked all the wiring and the sensors.....next stop is changing the Parking Sensor Module. I know where it is, but for the life of me I cannot find a video showing how I remove the boot internal panel to get to it. Anyone out there know of a video I could access??!! Andrew Kennedy
Post #597580 Thu Apr 09 2020 7:03pm
It’s rarrly the module.
You remove the tie down hooks on the left side
Remove the side base trim
Then pull the left panel off
And disconnect power socket
Post #597583 Thu Apr 09 2020 7:19pm
andrew kennedy
Rear Sensor problem
Hi Andy K. Thanks for yours!!! Regarding the problem with my rear sensors misbehaving. When I took the rear bumper off, I found a section of the loom that could have been trapped and possible damaged.....but I'm not holding my breath. So....if all seems okay with the sensors and the loom, any suggestions as to what else to check? My only other thought was that it could possible be the module. Andrew Kennedy
Post #597601 Fri Apr 10 2020 11:20am
you still got the bumper off ?
Post #597610 Fri Apr 10 2020 3:35pm
andrew kennedy
Bumper is back on........but give me a good reason to take it off and I will. Andrew Kennedy
Post #597612 Fri Apr 10 2020 4:34pm
