![]() | Home > General > Rear Sensor problem/WD40?? |
| Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321
That’s what I would do, or if you have Vasalene (petroleum jelly) I use that a lot on electrical connections to keep damp out.
| insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533
While I doubt very much if 12V would track across WD40, I do know it is not a good insulator so I wouldn't use it on electrical connections (I've seen it smoke on 120V lighting connections). I use what's meant for them, spray electrical contact cleaner which is an acid type cleaner and should clean them nicely, preferably if you can rub with a 3M abrasive pad (green dishwash sponge will do) but avoid emery or similar as this removes the contacts coating if there is any left. Then a dielectric grease should prevent future corrosion, but at that low voltage vaseline or other grease would probably be fine. 13MY Range Rover Sport Autobiography SDV6 - mine
| All times are GMT |
