Home > Maintenance & Modifications > Fluid Changes and other less common service items |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
In the absence of a flush machine, emptying the oil twice is the usual way. It doesn't do a full change, sadly, as most fluid is "stuck" in the torque converter. Might be worth leaving that until you can get to a flush-equipped garage. Changing the pan/filter doesn't seem to be that useful.
Mon Apr 06 2020 10:22pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
and a Power Steering fluid flush..? Siphon off some, add new, siphon off some, add new, repeat. Alternatively, drop the lot, fill, bleed etc. Visitor from fullfatrr.com
Tue Apr 07 2020 8:04am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Gearbox fluid - don't just drop from the box and refill, you won't get enough out. Replace all of the fluid. It isn't a complex or difficult job to do and you do not need a flushing machine. It's easy enough to do this yourself with a pressure sprayer, some hose pipe and an hour of your time on your driveway.
Tue Apr 07 2020 8:28am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
I’ve just had a major service on mine and it only has 77k but is 14 years old. Coolant change, brake fluid change, cambelt + oil pump, front diff fluid change, TB & rear diff done last year and finally some rectification work.
Tue Apr 07 2020 10:43am |
jmadro Member Since: 21 Nov 2019 Location: sevilla Posts: 3 |
Tue Apr 07 2020 12:39pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Thanks all.
Tue Apr 07 2020 10:34pm |
How come you're replacing the steering rack, Derek?
Wed Apr 08 2020 10:07pm |
Replacing the rack as there's a bit too much play in it for my liking and my mechanic picked up on it being very worn at the last inspection and advised that replacement would likely be needed.
Thu Apr 09 2020 8:39am |
