Home > In Car Electronics > TYDV8 Inlet maniforld repair engine wont fire
GerryG
Scotland
Hi
Has anyone replaced the inlet manifold ( cracked ) ans had issues with non firing
Stripped mine down to replace the inlet, buttoned it all back up and it turns over but wont fire, rechecked all plugs etc, cracked injectors, pulling fuel through but still nothing.
WD down the throttle bodies still nothing, not even a sign of choke
Any ideas?
Gerry
Post #597307 Fri Apr 03 2020 8:51pm
Disco_Mikey
Last one I done took around 30 seconds of cranking to fire up
Otherwise, it's highly likely you have left a plug off someplace
Favourite would be the cam sensor at the back of the head. Guess how I know Laughing
Do you have access to a code reader at all?
Post #597311 Fri Apr 03 2020 10:15pm
GerryG
Scotland
Hi Mikey
Iam going to retrace my steps and check.
Dont have a code reader to hand ( bumer I kow )
Gotcha on the cam sensor Very Happy
Thanks for the advice
Post #597319 Sat Apr 04 2020 7:26am
GerryG
Scotland
Cant see the cam sensor, it coughed and spluttered there but still nothing, racking my brain with this one
Post #597340 Sat Apr 04 2020 12:05pm
Disco_Mikey
Cam sensor is on the back of the passenger side head
But if it coughed, it's not likely to be that.
Post #597343 Sat Apr 04 2020 12:58pm
GerryG
Scotland
I have checked the wiring,nothing loose, looked at the schrader valve,should it continue to spurt fuel from it, it died after about 5 times ive pressed it.
Post #597345 Sat Apr 04 2020 1:18pm
GerryG
Scotland
If you have time Mickey would appreciate if you could talk me round a few things to try.
Happy to send ypu a few quid through paypal or bank etc
Gerry
Post #597346 Sat Apr 04 2020 1:41pm
Disco_Mikey
I'll be honest, without at least a basic code reader, you'll be Censored in the wind...
Post #597360 Sat Apr 04 2020 6:04pm
GerryG
Scotland
Aye kind f guessed that
Have you ever came across this.
Was spraying fuel down the throttle and, turned it over and it just stopped dead, now all it does is click from somewhere?
Thinking starter but not sure.
Tried it this morning and it just clicks, nothing from it
Post #597383 Sun Apr 05 2020 12:04pm
